[mapserver-users] postgis to spatile-ogr
Sebastian E. Ovide sebastian.ovide at gmail.com
Thu Oct 21 18:35:13 EDT 2010
if you need only to display geometries with mapserver u can simply use
shapes files... anything that can be read by gdal can be read by mapserver
On Thu, Oct 21, 2010 at 2:38 PM, <nikos at maich.gr> wrote:
> Hello,
> Was wondering if an application that is currently set up with postgis data
> sources can work directly by changing only the data source, e.g change the
> DATA string to "ogr" in the mapfile.
> Have to setup a demo remotely and don't really want to drag pgsql along
> only for the demo.
> If, so, would ogr2ogr be the most direct way to dump the postgis tables
> into sqlite?
> regards,
> nicolas boretos
> mapserver-users at lists.osgeo.org
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101021/ef3adc27/attachment.html
