[mapserver-users] Best way to store ArcInfo annotations in PostGIS?
Martin Ouellet
geomartino at gmail.com
Fri Oct 22 11:49:08 EDT 2010
Hi all,
I see 2 ways for doing that:
1) store the centroid (as a point geometry), rotation, text and maybe the
size of the annotation in my postgis table
2) using FME transformer (TextStroker), I can convert the annotation as a
multi-polygone or polyline directly. Playing with the font and some offset
parameter, the result is pretty amazing (when I overlap the annotation and
the geometry generated by the transformer)
In a WMS map rendering point of view:
Q1: I presume that the solution #2 will be much faster than rendering à
label based on a point, rotation and text?
Q2: beside the limitation of solution #2 (cannot change font, size or
position of the text (geometry), is there others importants limitations that
I forgot?
Q3: Any recommendations?
cheers!
MartinOuellet
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101022/e854a30a/attachment.html
