[mapserver-users] Trouble with MapServer cgi
Sebastian E. Ovide
sebastian.ovide at gmail.com
Sat Oct 23 08:46:56 EDT 2010
Hi Leigh,
I have not idea about Fedora... with Ubuntu it was a simple apt-get
install... with GIS repo...that's all... all working fine... In my case I
had to build gdal and mapserver as I needed Oracle drivers too.... and the
installation was very straight forward...
What OS do mapservers developers use ?
On Sat, Oct 23, 2010 at 10:16 AM, Leigh Holcombe <
lholcombe at triple-bypass.net> wrote:
> Hello,
> I've been trying to learn the MapServer software for a few weeks now.
> Mostly, I've been running some examples from Bill Kropla's book, but I've
> also been trying out some things on my own. I'm running version 5.6.5 on
> Fedora 13.
> My first question is about SELinux context. After yum installation, the
> mapserv executable found in /usr/sbin has a context of
> system_u:object_r:bin_t:s0. However, this causes serious problems for
> SELinux. After trying numerous modifications, I have found that
> unconfined_u:object_r:httpd_unconfined_script_exec_t:s0 works - however,
> according to documentation, this is just barely better than turning SELinux
> off. Can you offer any advice about setting this properly? While SELinux
> is not crucial to my practice development, I feel it's a good idea to learn
> it.
> Secondly, I am having trouble loading map images without forms. I have a
> properly configured virtual host, whose docroot is /var/www/html/nwss.dev.
> My cgi directory is /var/www/cgi-bin, and my mapfile is located in
> /var/www/html/nwss.dev/mapserver_test. According to the documentation, the
> path passed to the executable should be the path relative to the cgi
> location. I take this to mean that either the absolute path above or the
> relative path ../html/nwss.dev/mapserver_test should work. However, it does
> not. Here is the HTML code I am trying to use (without < >):
> img src="
> http://www.nwss.dev/cgi-bin/mapserv?map=../html/nwss.dev/mapserver_test/map_13.map?mode=map"
> width="800" height="800" border="0"
> The web section (is it necessary in this example?) of my mapfile is:
> WEB
> TEMPLATE "/var/www/html/nwss.dev/mapserver_test/map_13.html"
> IMAGEPATH "/var/www/html/nwss.dev/mapserver_test/tmp/"
> IMAGEURL "/mapserver_test/tmp/"
> END #end web
> Clearly, I'm doing something wrong. But based on what I've read, it seems
> right. Help! Thanks for your time.
> mapserver-users at lists.osgeo.org
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101023/77ee2d12/attachment.html
