[mapserver-users] Dinamic SLD style
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Oct 25 09:29:22 EDT 2010
Hi there,
It is possible to do attribute binding on some elements but It was not
implemented for the Graphic symbol property name. I have added that
support in trunk. It is described in the bug 3586 [1].
You might want to add your name to that bug and comment on it.
regards,
[1]: http://trac.osgeo.org/mapserver/ticket/3586
On 25/10/2010 5:55 AM, Joaquín Rodriguez-Guerra Urcelay wrote:
> Hello, I am trying to create a dinamic sld style for a shapefile in mapserver. I come from geoserver, and I was wondering if there was any way to use properties of the shapefile in the sld style, as in the example below where points in the shapefile with tipo=3 are represented with a ship3.png rotated COG deegrees. Is this possible in mapserver? Thanks for your help!
> <Rule>
> <Title>ship3</Title>
> <ogc:Filter>
> <ogc:PropertyIsEqualTo>
> <ogc:PropertyName>Tipo</ogc:PropertyName>
> <ogc:Literal>3</ogc:Literal>
> </ogc:PropertyIsEqualTo>
> </ogc:Filter>
> <PointSymbolizer>
> <Graphic>
> <ExternalGraphic>
> <OnlineResource
> xlink:type="simple"
> xlink:href="ships/ship3.png" />
> <Format>image/png</Format>
> </ExternalGraphic>
> <Size>16</Size>
> <Rotation><ogc:PropertyName>COG</ogc:PropertyName></Rotation>
> </Graphic>
> </PointSymbolizer>
> </Rule>
> Joaquín Rodríguez-Guerra Urcelay
> ______________________
> This message including any attachments may contain confidential
> information, according to our Information Security Management System,
> and intended solely for a specific individual to whom they are addressed.
> Any unauthorised copy, disclosure or distribution of this message
> is strictly forbidden. If you have received this transmission in error,
> please notify the sender immediately and delete it.
> Este mensaje, y en su caso, cualquier fichero anexo al mismo,
> puede contener informacion clasificada por su emisor como confidencial
> en el marco de su Sistema de Gestion de Seguridad de la
> Informacion siendo para uso exclusivo del destinatario, quedando
> prohibida su divulgacion copia o distribucion a terceros sin la
> autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
> erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
> Gracias por su colaboracion.
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
