[mapserver-users] Best way to store ArcInfo annotations in
PostGIS?
Martin Ouellet
geomartino at gmail.com
Tue Oct 26 09:54:56 EDT 2010
Thanks Daniel for your inputs,
The beauty of the solution #2 (stroked text) is that the result is visually
exactly the same than the annotation layer in ArcInfo (size, font, position,
orientation, etc...). To obtain the same result with the labeling options
would require a lot of tuning(adjustment in the mapfile pour each layer),
but I may be wrong.
I will keep all the info for both solutions (text as polygon, centroid,
text, angle) so I may execute some benchmark later this fall
cheers
MartinO
2010/10/25 Daniel Morissette <dmorissette at mapgears.com>
> Martin,
> Only some benchmarks could tell us for sure, but I don't imagine that
> option 1 would be that much slower than option 2, if it's slower at all.
> Once the text has been stroked in option 2, you cannot change its style
> or size any more. OTOH, with #1 you keep all that flexibility.
> Personally I'd go with #1 unless you can verify with some tests that #2
> is really faster, and if that's the case we'd like to hear back from you
> and find out more.
> Daniel
> Martin Ouellet wrote:
> > Hi all,
> > I see 2 ways for doing that:
> > 1) store the centroid (as a point geometry), rotation, text and maybe
> > the size of the annotation in my postgis table
> > 2) using FME transformer (TextStroker), I can convert the annotation as
> > a multi-polygone or polyline directly. Playing with the font and some
> > offset parameter, the result is pretty amazing (when I overlap the
> > annotation and the geometry generated by the transformer)
> > In a WMS map rendering point of view:
> > Q1: I presume that the solution #2 will be much faster than rendering ą
> > label based on a point, rotation and text?
> > Q2: beside the limitation of solution #2 (cannot change font, size or
> > position of the text (geometry), is there others importants limitations
> > that I forgot?
> > Q3: Any recommendations?
> > cheers!
> > MartinOuellet
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101026/66991754/attachment.html
