[mapserver-users] question about joining
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 26 12:56:59 EDT 2010
Hi Mark,
Your interpretation of the existing JOIN documentation
(http://www.mapserver.org/mapfile/join.html) is correct, you can only
use the JOIN feature for query templates.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 10-10-26 12:28 PM, Mark Volz wrote:
> Hello,
> I have not used the Join shapefile to database function in mapserver
> before. I just have a couple questions
> ·The description explains that“It is important to understand that JOINs
> are/ONLY/available once a query has been processed. You cannot use joins
> to affect the look of a map.”Does that mean that we can only use the
> joins for templates. If possible, I would like tolabel using a field in
> a joined table.
> ·Is the following formatted correctly
> #CLASSITEM 'PARC_CODE'
> JOIN #TEST
> NAME "MyJoin"
> TABLE "LyonCounty/Parcels/test.dbf"#location of the dbf file
> FROM "PARCEL_ID"#shapefile field
> TO "PIN"#dbf field
> TYPE ONE-TO-ONE
> END #JOIN
> TEXT (“Name”* [MyJoin_MYNAME]) #labelusing the joined table
> Thanks
> Mark Volz
> GIS Specialist
> Lyon County, MN
