[mapserver-users] Re: Reading raster data source dynamically
Alexander Petkov greenkov at gmail.com
Tue Oct 26 13:14:45 EDT 2010
Hey Roger:
I am interested to find out if you have a solution to the problem you
talked about below.
Thanks,
Alex
On Thu, Feb 12, 2009 at 6:32 PM, Roger André <randre at gmail.com> wrote:
> Or maybe creating a GDAL "In Memory Raster" and then pointing to it as the
> data source for the mapscript layer?
> On Thu, Feb 12, 2009 at 3:46 PM, Roger André <randre at gmail.com> wrote:
>> Hi All,
>> I'm wondering if there is some way I could feed Mapserver a raster data
>> source dynamically?  Like maybe constructing a GeoTIFF in memory from a
>> numerical array, and then passing that into mapscript along with the rest of
>> the layer info.  The goal here is to avoid having to create temporary image
>> files for each of the raster layers that I'm mapping.
>> Any idea here would be welcome.
>> Thanks,
>> Roger
> mapserver-users at lists.osgeo.org
