[mapserver-users] Polygon hatch mismatch at tile borders.
Stephen Woodbridge woodbri at swoodbridge.com
Thu Oct 28 09:19:36 EDT 2010
On 10/28/2010 9:00 AM, Ausderau Larissa LT wrote:
> Thanks Alex,
> The "gutter" solution gives something better and the "singleTile"
> solve the problem.
> Unfortunately I can't use them, because we are pre-generating tiles
> in order to have good performances, which means that I need a
> solution at the level MapServer (Mapfile and / or symbol file).
> I've found that in The MapServer RFC Documentation
> http://mapserver.org/development/rfc/ms-rfc-45.html:
> ----------------------------------------------------- Polygon fill
> symbols
> Give hatches and vector fills a stable geographical coordinate origin
> (0,0) to better support tiling and continuous rendering of
> neighboring polygons
> Does it mean that the problem is known and  have been fixed?
Larissa,
Have you check to see it there is an open bug for this?
The RFC would seem to indicate that the problem is known. And that it
was considered in RFC45, but it is not clear from the RFC that it was
actually solved as there is no bug number at the bottom that
specifically tracks that particular change. This RFC was targeted for
Mapserver 5.4.
If you are on 5.4 or later then you might want to get a ticket opened
asap, and maybe a fix can get put in 6.0 to resolve this.
Steve L, Thomas B, - Do you guys know if this was tackled or not?
-Steve W
> Best regards!
> Larissa
> -----Message d'origine----- De : Strunck, Alexander
> [mailto:strunck at bicc.de] Envoyé : jeudi, 28. octobre 2010 12:21 À :
> Ausderau Larissa LT; 'mapserver-users at lists.osgeo.org' Objet : AW:
> Hello
> you can use the parameter "gutter". Here an example
> http://trac.osgeo.org/openlayers/browser/trunk/openlayers/examples/gutter.html
>  Or you can use the parameter onetile. Here another example
> http://dev.openlayers.org/releases/OpenLayers-2.9/examples/notile.html
>  alex
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von
> Ausderau Larissa LT Gesendet: Donnerstag, 28. Oktober 2010 12:01 An:
> 'mapserver-users at lists.osgeo.org' Betreff: [mapserver-users] Polygon
> Hi,
> I'm using MapServer 5.4.2 and when I'm working with tiles the hatches
> of hatch filled polygons are not matching at tile borders. See
> How can I solve that?
> Thanks
> Larissa _______________________________________________
> mapserver-users mailing list mapserver-users at lists.osgeo.org
