[mapserver-users] Polygon hatch mismatch at tile borders.
Wim Vanbelle
wimvanbelle at gmail.com
Fri Oct 29 08:09:43 EDT 2010
I mailed this list for an issue regarding lines that have a certain
thickness, that get cut off at the tile. Is this related to the same known
issue above?
So far I've been unable to resolve it using other suggestions. While using
openlayers I can effectively use gutter, but that is a client side solution.
I'd prefer something at the mapserver level as the client solution wouldn't
work on google or bing maps.
Steve Lime: this was the problem I reported to you a while ago. Maybe
there's an update on the case since then?
The original mail can be found at :
http://osgeo-org.1803224.n2.nabble.com/Mapserver-tile-generation-google-maps-td5444090.html#a5455480
Using tilecache is not an option, I'm dealing with realtime information.
Thanks.
On 28 October 2010 17:00, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Yes, the problem is known and hasn't been addressed yet. This one
> would be a candidate for 6.2.
> cheers,
> thomas
> On Thu, Oct 28, 2010 at 15:19, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
> > On 10/28/2010 9:00 AM, Ausderau Larissa LT wrote:
> >> Thanks Alex,
> >> The "gutter" solution gives something better and the "singleTile"
> >> solve the problem.
> >> Unfortunately I can't use them, because we are pre-generating tiles
> >> in order to have good performances, which means that I need a
> >> solution at the level MapServer (Mapfile and / or symbol file).
> >> I've found that in The MapServer RFC Documentation
> >> http://mapserver.org/development/rfc/ms-rfc-45.html:
> >> ----------------------------------------------------- Polygon fill
> >> symbols
> >> Give hatches and vector fills a stable geographical coordinate origin
> >> (0,0) to better support tiling and continuous rendering of
> >> neighboring polygons
> >> Does it mean that the problem is known and have been fixed?
> > Larissa,
> > Have you check to see it there is an open bug for this?
> > The RFC would seem to indicate that the problem is known. And that it was
> > considered in RFC45, but it is not clear from the RFC that it was
> actually
> > solved as there is no bug number at the bottom that specifically tracks
> that
> > particular change. This RFC was targeted for Mapserver 5.4.
> > If you are on 5.4 or later then you might want to get a ticket opened
> asap,
> > and maybe a fix can get put in 6.0 to resolve this.
> > Steve L, Thomas B, - Do you guys know if this was tackled or not?
> > -Steve W
> >> Best regards!
> >> Larissa
> >> -----Message d'origine----- De : Strunck, Alexander
> >> [mailto:strunck at bicc.de] Envoyé : jeudi, 28. octobre 2010 12:21 À :
> >> Ausderau Larissa LT; 'mapserver-users at lists.osgeo.org' Objet : AW:
> >> Hello
> >> you can use the parameter "gutter". Here an example
> http://trac.osgeo.org/openlayers/browser/trunk/openlayers/examples/gutter.html
> >> Or you can use the parameter onetile. Here another example
> >> http://dev.openlayers.org/releases/OpenLayers-2.9/examples/notile.html
> >> alex
> >> Von: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von
> >> Ausderau Larissa LT Gesendet: Donnerstag, 28. Oktober 2010 12:01 An:
> >> 'mapserver-users at lists.osgeo.org' Betreff: [mapserver-users] Polygon
> >> Hi,
> >> I'm using MapServer 5.4.2 and when I'm working with tiles the hatches
> >> of hatch filled polygons are not matching at tile borders. See
> >> How can I solve that?
> >> Thanks
> >> Larissa _______________________________________________
> >> mapserver-users mailing list mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101029/d3c9d9ce/attachment.html
