[mapserver-users] Problems with AGG rendering
Sharon Carter
carter.sharon017 at gmail.com
Fri Oct 29 19:46:24 EDT 2010
Hi Steve.
After you mentioned the tile aspect in your answer we started double
checking the tile creation scripts.
After a while we discovered that the problem was not on the metatile
creation with mapserver but rather on the tile creation functions we were
using to split the metatiles to create the tiles.
Thank you guys.
Sharon
2010/10/26 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> Can you post more of your mapfile including the AGG output format? Are
> your sample images from a single map draw or were they build from a number
> of tiles?
> Steve
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Sharon Carter
> *Sent:* Tuesday, October 26, 2010 4:16 PM
> *To:* thomas bonfort
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Problems with AGG rendering
> Thanks for the answer Thomas.
> I changed the definition per your suggestion, the map file is much cleaner
> now. But, we are still getting the same result with the rendering. In GD is
> working fine but in Agg the same weird colored areas keep showing up.
> --sharon
> 2010/10/26 thomas bonfort <thomas.bonfort at gmail.com>
> Rendering thick lines is done without symbols with agg (and GD with
> recent versions of mapserver to, I believe)
> for an outlined line, you use:
> CLASS
> STYLE
> COLOR outlinecolor
> WIDTH 5
> END
> STYLE
> COLOR fillcolor
> WIDTH 3 #width of the first style minus 2 times the desired outline
> width
> END
> END
> regards,
> thomas
> On Mon, Oct 25, 2010 at 19:21, Sharon Carter <carter.sharon017 at gmail.com>
> wrote:
> > Hello,
> > We have been working with mapserver for a while and now we are updating
> our
> > map. We decided to give AGG a try for this new version but we have been
> > having some troubles setting it up to work properly.
> > When we moved from GD to AGG the map starting showing areas with
> different
> > colors than the ones specified in the map file.
> > Here we have an image with the rendering with GD
> > http://67.23.24.210/mapserver/gd.png
> > And one with AGG http://67.23.24.210/mapserver/agg.png
> > The output format for AGG we are using is
> > OUTPUTFORMAT
> > NAME 'PNG'
> > DRIVER AGG/PNG
> > IMAGEMODE RGBA
> > MIMETYPE "image/png;mode=24bit"
> > FORMATOPTION "FORMAT=image/png"
> > END
> > The street lines are painted using a symbol to create the outline for the
> > streets.
> > Any ideas what could be causing this?
> > Thanks
> > Sharon
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101029/18d444b9/attachment.html
