[mapserver-users] Symbology
Michael Schulz
mschulz at webgis.de
Thu Sep 16 11:26:32 EDT 2010
Jay,
you need to reference the symbolset file in the map section of you mapfile
SYMYBOLSET '/path/to/your/symbolset.sym'
then you can simply use the names of the defined symbols.
Cheers, Michael
2010/9/16 Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>:
> Thanks guys for your thoughts...still green to this and trying to learn
> I would make real sense to me to create the .sym file where I would not have
> to redefine the particular symbol sets
> DO I HAVE THIS RIGHT?
> 1. BUT how do I define the symbol set or point to the .sym file from the
> map file ?????
> SYMBOL FILE: So in the Symbol file I would have this (example of two of
> them)
> SYMBOL
> NAME 'bike'
> TYPE pixmap
> IMAGE '/home/mapserv/proj/pmap/bike.png'
> TRANSPARENT 2
> END
> SYMBOL
> NAME 'church'
> TYPE pixmap
> IMAGE '/home/mapserv/proj/pmap/church.png'
> TRANSPARENT 5
> END
> MAP FILE: I would simply call them?
> CLASS
> STYLE
> SYMBOL "bike"
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> END
> END
> -----Original Message-----
> From: Fawcett, David (MPCA) [mailto:David.Fawcett at state.mn.us]
> Sent: Thursday, September 16, 2010 9:50 AM
> To: Jay Kapalczynski; 'Michael Schulz'
> Cc: mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] Symbology
> You can put the symbol definition in your map file, or in a symbols file
> (e.g. symbols.sym) and then set SYMBOLSET at the MAP level to point to your
> symbols.sym file.
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jay
> Kapalczynski
> Sent: Thursday, September 16, 2010 9:45 AM
> To: 'Michael Schulz'
> Ok that seems to make sense...but where do I place the image SYMBOL (your
> example below)? DO I place that in the map file as well?
> Little confused there....
> Thanks Michael and Adam for your return replys.
> From: mandschulz at googlemail.com [mailto:mandschulz at googlemail.com] On Behalf
> Of Michael Schulz
> Sent: Thursday, September 16, 2010 9:27 AM
> Subject: Re: [mapserver-users] Symbology
> Hi,
> yes, you have to define an image symbol in your symbolset and use that:
> SYMBOL
> NAME 'church'
> TYPE pixmap
> IMAGE 'church.gif'
> TRANSPARENT 5
> END
> then use
> SYMBOL 'church' in your style.
> Cheers, Michael
>> In a map file...Is there a way to use an image (jpg, bmp, png) instead of
>> a
>> marker symbol (star, circle etc) when symbolizing points
>> LAYER
>> DUMP TRUE
>> NAME 'Firestations'
>> DATA 'firestations'
>> TYPE POINT
>> STATUS ON
>> CLASS
>> NAME 'Fire Stations'
>> COLOR 254 0 0
>> INSTEAD OF STAR PLACE AN IMAGE
>> SYMBOL "star"
>> SIZE 8
>> END
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-academy.eu/
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100 Freiburg i. Br.
> Tel: +49 (0)761 705798-102
> Tel: +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
Schwimmbadstraße 2
