[mapserver-users] reprojection
Julien Cigar
jcigar at ulb.ac.be
Wed Sep 22 03:45:15 EDT 2010
On 09/22/2010 08:36, Rahkonen Jukka wrote:
> Hi,
> For sure the original image is not in EPSG:4326. You can guess it from the coordinates, for example
> Origin = (-8563840.575678950175643,6466755.550653258338571)
> EPSG:4326 is naturally between -90,90 and -180,180. There does read
> AUTHORITY["EPSG","4326"]] in one place of the gdalinfo report, but it is in the section that tells the datum or the projection.
> I am not sure what the right projection could be, but I found this projection wiht the same lookin parametrers
> from my Mapserver proj directory:
> # WGS 84 / Antarctic Polar Stereographic
> <3031> +proj=stere +lat_0=-90 +lat_ts=-71 +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs<>
> If this is correct, you do not need to reproject at all because your image is already in EPSG:3031.
> -Jukka Rahkonen-
Thanks for the clarification, looks like I misunderstood the output of
gdalinfo..!
Julien
>> -----Alkuperäinen viesti-----
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Julien Cigar
>> Lähetetty: 21. syyskuuta 2010 22:09
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: [mapserver-users] reprojection
>> Hello,
>> I'm trying to re-project a RASTER layer but without success so far.
>> I have the following TIFF file:
>> mage at mordor:/home/mage/gis % gdalinfo antarctica_sthn_ocean.tiff
>> Driver: GTiff/GeoTIFF
>> Files: antarctica_sthn_ocean.tiff
>> Size is 12216, 9094
>> Coordinate System is:
>> PROJCS[" Projection Name = WGS_1984_Stereographic_South_Pole Units =
>> meters GeoTIFF Units = meters",
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]],
>> PROJECTION["Polar_Stereographic"],
>> PARAMETER["latitude_of_origin",-71],
>> PARAMETER["central_meridian",0],
>> PARAMETER["scale_factor",1],
>> PARAMETER["false_easting",0],
>> PARAMETER["false_northing",0],
>> UNIT["metre",1,
>> AUTHORITY["EPSG","9001"]]]
>> Pixel Size = (1420.390210742724321,-1420.394765779645695)
>> Metadata:
>> TIFFTAG_XRESOLUTION=900
>> TIFFTAG_YRESOLUTION=900
>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left (-8563840.576, 6466755.551) ( 52d56'33.71"W, 8d
>> 9'27.23"S)
>> Lower Left (-8563840.576,-6450314.449) (126d59'13.87"W,
>> 8d12'36.90"S)
>> Upper Right ( 8787646.239, 6466755.551) ( 53d39'3.45"E, 7d12'35.07"S)
>> Lower Right ( 8787646.239,-6450314.449) (126d16'45.99"E,
>> 7d15'38.97"S)
>> Center ( 111902.832, 8220.551) ( 85d47'54.65"E, 88d58'2.41"S)
>> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
>> Overviews: 6108x4547, 3054x2274, 1527x1137, 764x569
>> Metadata:
>> LAYER_TYPE=athematic
>> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
>> Metadata:
>> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
>> Metadata:
>> If I understood well the output of gdalinfo, the projection
>> seems to be
>> EPSG:4326.
>> Now I want to re-project this to EPSG:3031.
>> I tried with the following MAP file :
>> MAP
>> NAME "antarctic"
>> STATUS ON
>> SIZE 600 400
>> EXTENT -8563840.576 -6450314.449 8787646.239 6466755.551
>> IMAGECOLOR 255 255 255
>> PROJECTION
>> "init=epsg:3031"
>> END
>> OUTPUTFORMAT
>> NAME png
>> DRIVER "GD/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE RGBA
>> EXTENSION "png"
>> END
>> LAYER
>> NAME "ocean"
>> TYPE RASTER
>> STATUS DEFAULT
>> DATA antarctica_sthn_ocean.tiff
>> PROJECTION
>> "init=epsg:4326"
>> END
>> END
>> END
>> ... but all what I get is a gray 600x400 PNG image ...
>> Any idea what could be the problem ?
>> Thanks,
>> Julien
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100922/452d1739/jcigar-0001.vcf
