[mapserver-users] lighttpd, TNS:could not resolve...
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Sep 30 04:54:50 EDT 2010
no luck...
renamed servicename to capital.. so now connection name==service name...
same problem... ogrinfo works, mapserver doesn't....
On Thu, Sep 30, 2010 at 9:37 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> For me, sometimes with some Oracle user name from some computers SQL*Plus
> does not understand if I am using the SERVICE_NAME. It you happen to have
> the same situation you should be able to connect with the connection name,
> which seems to be MFUATDB for you.
> Actually, the error message "TNS:could not resolve the connect identifier
> specified" may mean that you should not use service name but the connect
> identifier. Have a try and tell how it went.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Sebastian E. Ovide
> *Lähetetty:* 30. syyskuuta 2010 11:15
> *Vastaanottaja:* Dan Little
> *Kopio:* mapserver-users at lists.osgeo.org
> *Aihe:* Re: [mapserver-users] lighttpd, TNS:could not resolve...
> yes.
> gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
> -rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
> gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
> MFUATDB =
> (DESCRIPTION =
> (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
> (CONNECT_DATA =
> (SERVER = DEDICATED)
> (SERVICE_NAME = mfuatdb)
> On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
>> Is tnsnames.ora accessible by the web-server user? (Check the
>> permissions.)
>> Is t
>> *From:* Sebastian E. Ovide <sebastian.ovide at gmail.com>
>> *To:* mapserver-users at lists.osgeo.org
>> *Sent:* Wed, September 29, 2010 11:10:09 AM
>> *Subject:* [mapserver-users] lighttpd, TNS:could not resolve...
>> Hi All,
>> I have installed MapServer on lighttpd + fastcgi.
>> fastcgi.server = (
>> "/mapserver" =>
>> ( "localhost" =>
>> "socket" => "/tmp/mapserver-fastcgi.socket",
>> "bin-path" => "/home/gis/bin/mapserv",
>> "bin-environment" =>
>> "TNS_ADMIN" => "/home/gis/conf/"
>> "max-procs" => 2,
>> "check-local" => "disable"
>> gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
>> MFUATDB =
>> (DESCRIPTION =
>> (CONNECT_DATA =
>> and I'm getting:
>> msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
>> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>> `TESTII'. ORA-12154: TNS:could not resolve the connect identifier specified
>> in <unnamed>
>> from the logs:
>> [Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
>> [Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open failed
>> for OGR connection in layer `TESTII'.
>> in <unnamed>
>> [Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error.
>> [Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at 0xa00f298.
>> [Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at 0xa0237a0.
>> [Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at 0xa024718.
>> in mapserver:
>> LAYER
>> NAME TESTII
>> TYPE POLYGON
>> STATUS ON
>> CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
>> CONNECTIONTYPE OGR
>> DATA "CA_WILDFIRE"
>> PROJECTION
>> "init=epsg:3857"
>> END
>> CLASS
>> # NAME "local_shape"
>> COLOR 0 0 255
>> OUTLINECOLOR 0 0 255
>> END
>> END
>> The connection string is right as I'm using it from gdal:
>> gis at mapserver:~$ ogrinfo OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE
>> INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
>> using driver `OCI' successful.
>> 1: CA_WILDFIRE
>> any ideas ?
>> Sebastian E. Ovide
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/6249ea54/attachment-0001.html
