[mapserver-users] lighttpd, TNS:could not resolve...
Dan Little danlittle at yahoo.com
Thu Sep 30 07:22:16 EDT 2010
Does shp2img work with your Mapfile?
>From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
>To: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>Cc: mapserver-users at lists.osgeo.org
>Sent: Thu, September 30, 2010 4:47:30 AM
>Subject: Re: [mapserver-users] lighttpd, TNS:could not resolve...
>the message says:
>ORA-12154: TNS:could not resolve the connect identifier specified in <unnamed>
>so... does <unnamed> mean that gdal didn't get any name for the connection ?
>On Thu, Sep 30, 2010 at 9:54 AM, Sebastian E. Ovide <sebastian.ovide at gmail.com>
>wrote:
>no luck...
>>renamed servicename to capital.. so now connection name==service name...
>>same problem... ogrinfo works, mapserver doesn't....
>>On Thu, Sep 30, 2010 at 9:37 AM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>>wrote:
>>Hi,
>>>For me, sometimes with some Oracle user name from some  computers SQL*Plus does
>>>not understand if I am using the SERVICE_NAME.  It  you happen to have the same
>>>situation you should be able to connect with the  connection name, which seems
>>>to be MFUATDB for you.
>>>Actually, the error message "TNS:could not resolve the  connect identifier
>>>specified" may mean that you should not use service name but  the connect
>>>identifier.  Have a try and tell how it  went.
>>>-Jukka  Rahkonen-
 Lähettäjä: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Sebastian E.    Ovide
>>>>Lähetetty: 30. syyskuuta 2010 11:15
>>>>Vastaanottaja: Dan Little
>>>>Kopio: mapserver-users at lists.osgeo.org
>>>>Aihe: Re: [mapserver-users] lighttpd, TNS:could not resolve...
>>>>yes.
>>>>gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
>>>>-rw-r--r-- 1 gis gis 184 2010-09-29 16:19    /home/gis/conf/tnsnames.ora
>>>>gis at mapserver:~$ sudo su www-data -c 'cat    /home/gis/conf/tnsnames.ora'
>>>>MFUATDB =
>>>>  (DESCRIPTION =
>>>>    (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT    = 1521))
>>>>    (CONNECT_DATA =
>>>>      (SERVER = DEDICATED)
>>>>      (SERVICE_NAME = mfuatdb)
>>>>On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
>>>>Is tnsnames.ora accessible by the web-server user? (Check the
>>>permissions.)
>>>>>Is        t
>>>>>>To: mapserver-users at lists.osgeo.org
>>>>>>Sent: Wed, September 29, 2010        11:10:09 AM
>>>>>>Subject: [mapserver-users] lighttpd, TNS:could not resolve...
>>>>>>Hi All,
>>>>>>I have installed MapServer on lighttpd + fastcgi.
>>>>>>fastcgi.server = (
>>>>>>        "/mapserver" =>
>>>>>>        ( "localhost" =>
>>>>>>                               "socket" =>
"/tmp/mapserver-fastcgi.socket",
>>>>>>                               "bin-path" => "/home/gis/bin/mapserv",
>>>>>>                               "bin-environment" =>
>>>>>>                                       "TNS_ADMIN" =>
>>>"/home/gis/conf/"
>>>>>>                               "max-procs" => 2,
>>>>>>                               "check-local" => "disable"
>>>>>>gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
>>>>>>MFUATDB =
>>>>>>  (DESCRIPTION =
>>>>>>    (CONNECT_DATA =
>>>>>>and I'm getting:
>>>>>>msDrawMap(): Image handling error. Failed to draw layer named        'TESTII'.
>>>>>>msOGRFileOpen(): OGR error. Open failed for OGR connection in        layer
>>>>>>`TESTII'. ORA-12154: TNS:could not resolve the connect identifier
>>>>>>from the logs:
>>>>>>[Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
>>>>>>[Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open        failed
>>>>>>for OGR connection in layer `TESTII'.
>>>>>> in <unnamed>
>>>>>>[Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error.
>>>>>>[Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at
>>>>0xa00f298.
>>>>>>[Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at
>>>>>>0xa0237a0.
>>>>>>[Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at
>>>>>>0xa024718.
>>>>>>in mapserver:
>>>>>>  LAYER
>>>>>>    NAME TESTII
>>>>>>    TYPE POLYGON
>>>>>>    STATUS ON
>>>>>>    CONNECTION        "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
>>>>>>    CONNECTIONTYPE OGR
>>>>>>    DATA "CA_WILDFIRE"
>>>>>>    PROJECTION
>>>>>>      "init=epsg:3857"
>>>>>>    END
>>>>>>    CLASS
>>>>>>#      NAME "local_shape"
>>>>>>      COLOR 0 0 255
>>>>>>      OUTLINECOLOR 0 0 255
>>>>>>    END
>>>>>>  END
>>>>>>The connection string is right as I'm using it from gdal:
>>>>>>gis at mapserver:~$ ogrinfo
>>>>OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE
>>>>>>INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
>>>>>>      using driver `OCI' successful.
>>>>>>1: CA_WILDFIRE
>>>>>>any ideas ?
>>>>>>Sebastian E.        Ovide
>>>>Sebastian E. Ovide
>>Sebastian E. Ovide
>Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/564d9715/attachment-0001.html
