[mapserver-users] tutorial assistance
Daniel Morissette
dmorissette at mapgears.com
Sun Apr 3 09:51:23 EDT 2011
On 11-04-03 09:26 AM, martin crook wrote:
> when I use the command in the browswer:
> <http://localhost/cgi-bin/mapserv&map=/var/www/html/mapserver/Example1-1.map&layer=states&mode=map>"
> I get the following output:
Try using:
http://localhost/cgi-bin/mapserv?map=/var/www/html/mapserver/Example1-1.map&layer=states&mode=map
The first delimiter after the mapserv program name should be a "?"...
and then "&" are used between the parameters in the QUERY_STRING part
of the URL.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
