[mapserver-users] how do min/max scale filters work?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Apr 6 13:49:11 EDT 2011
Are you testing with WMS requests? If yes, I would suggest to read and follow the document
http://mapserver.org/ogc/wms_server.html. You need more WMS metadata for making a really working WMS service.
If you are testing with Mapserver CGI calls and error message is just misleading with the WMS hint, I am not sure what happens. Myself I have always PROJECTION at LAYER level as well because it gives me a feeling that I am controlling the situation better if I do not need to rely on the defaults. However, it is not compulsory to have LAYER-PROJECTION if all the layers are using the same projection as the whole MAP and you configuration should work.
And add DEBUG 5 into your LAYER. It gives faster feedback than this mailing list.
-Jukka Rahkonen-
PixelPusher wrote:
> Hmmm... interesting...
> When I change to STATUS ON I get an error saying, "msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS must be valid for all requested layers."
> At the top of each of the mapfiles used in this map, I define the projection as:
PROJECTION
"init=epsg:4269"
END
> And that matches the srid for all of the layers.
---- Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
>> Hi,
>> I would first change the layer to have STATUS ON. Now you are giving ambiguous instructions "draw layer always" and "draw just at this scale range". It may be something else, though, but it does not cost much to try.
> -Jukka Rahkonen-
>> PixelPusher wrote:
>> > I've got a simple thing in a MapServer page that doesn't want to work. There is a layer in my map that I only want displayed if the scale of the view is between 1:24000 and 1:100000. However, I've had no luck using the MAXSCALEDENOM and MINSCALEDENOM keywords. As configured below, the layer never draws, regardless of the scale. The layer draws correctly if I comment out the scale tests. Can anyone show me the correct way to use this?
> The relevant section of the mapfile looks like this:
> LAYER
> NAME "BTSroads_local_PostGIS"
> TYPE LINE
> STATUS DEFAULT
> MAXSCALEDENOM 100000
> MINSCALEDENOM 24000
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=mapserver user=uuuu password=pppp port=5432"
> DATA "wkb_geometry from btsroads using unique ogc_fid using srid=4269"
> FILTER "fcc LIKE 'A4%'"
> CLASS
> NAME "Local Roads"
> STYLE
> COLOR 220 214 196
> END
> END
> END # layer
> Thanks,
> Thom
> Man will occasionally stumble over the truth, but most of the time
> he will pick himself up and continue. -- Winston Churchill
> mapserver-users at lists.osgeo.org
