[mapserver-users] error in raster layer
fruitwerks
fruitwerks at gmail.com
Fri Apr 8 02:45:49 EDT 2011
That error is fairly vague. The first thing I would look at is
permissions. Also a good rule of thumb is to not use () in file or
directory names.
On Thu, Apr 7, 2011 at 9:16 PM, morteza shabihkhani
<m.shabihkhani at gmail.com> wrote:
> Hello all,
> I want to create a very simple raster layer, but I faced to this error:
> msDrawMap(): Image handling error. Failed to draw layer named 'elevation'.
> msDrawRaster(): Unable to access file. stcon using full path stcon
> this is my layer:
> LAYER
> NAME elevation
> TYPE raster
> STATUS on
> DATA stcon
> PROJECTION
> "init=epsg:2260"
> END
> CLASS
> STYLE
> OUTLINECOLOR 0 200 0
> END
> END
> END
> I checked paths and names, and everything is correct.
> I should note that I try to look at the only raster layer of itasca, but
> although all other layers are working very well, running this layer causes
> this error:
> msDrawMap(): Image handling error. Failed to draw layer named 'drgs'.
> msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format drawEPP(): Image handling error.
> /var/www/Mapserver/Amin(Itasca)/data/drgncimq1926.tif is not an EPPL file.
> Thank you in advance for your help.
> Amin
> mapserver-users at lists.osgeo.org
_______________________________________________________________________________
Any use, dissemination, distribution, posting on Internet bulletin
boards, disclosure or copying of this e-mail or any information
contained herein by or to anyone other than the intended recipient(s)
is strictly prohibited. Use of this content for any other purpose is a
violation of International Copyright Laws.
