[mapserver-users] Transparency of overlapping PNG-symbols [solved]
thomas bonfort
thomas.bonfort at gmail.com
Mon Apr 11 03:41:54 EDT 2011
Ok, thanks.
could you check the same mapfile with GD on mapserver 6.0 to see if
the issue still exists?
thomas
On Mon, Apr 11, 2011 at 09:39, Stephan Holl <stephan.holl at intevation.de> wrote:
> Hello thomas,
> thomas bonfort <thomas.bonfort at gmail.com>, [20110408 - 16:52:53]
>> Given the artifact, I'd say that you are using the GD renderer. Are
>> you sure it's the AGG one that is being selected when you create that
>> image?
> At least I was, yes, but after looking at the _right_ mapfile it was
> missing the AGG-rendering-options.
> setting the following helps.
> IMAGETYPE aggpng
> #8bit png, supports transparency.
> OUTPUTFORMAT
> NAME aggpng
> DRIVER AGG/PNG
> MIMETYPE "image/png"
> ## transparency only with RGBA Image Mode
> ## mapserver had to be compiled -with-experimental-png
> IMAGEMODE RGBA
> EXTENSION "png"
> FORMATOPTION "QUANTIZE_FORCE=ON"
> FORMATOPTION "QUANTIZE_COLORS=256"
> FORMATOPTION "QUANTIZE_NEW=ON"
> TRANSPARENT ON
> END
> Best regards
> Stephan
>> 2011/4/8 Lime, Steve D (DNR) <steve.lime at state.mn.us>:
>> > Can you share the batnight.png file? Any difference if you remove
>> > "TRANSPARENT 0"? It shouldn't have any effect since transparency is
>> > picked up from the pixmap. By chance does this work ok in 6.0?
>> > Steve
> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
> Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
> Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
