[mapserver-users] fastcgi mode with raster layer?
thomas bonfort
thomas.bonfort at gmail.com
Mon Apr 11 13:33:07 EDT 2011
Martin,
fastcgi will essentially give you speedups in these two cases:
* with slow-to-open data connections (i.e. oracle, some gdal/ogr
datasources?) if you use "CLOSE_CONNECTION=DEFER"
* and/or when the cost of creation of a process becomes non
negligible compared to the time that the mapserv process will actually
be running for each request.
basically, there is little advantage of using fastcgi if your map
draws are heavy, or if you are not using oracle connections.
YMMV,
thomas
On Mon, Apr 11, 2011 at 19:22, Martin Ouellet <geomartino at gmail.com> wrote:
> I've just activated the fastcgi mode (RHEL5 - Mapserver 5.6.3 - Httpd) on my
> server. is it normal to have no speed increase for a raster layer?
> Does the fastcgi mode is optimized mainly for database layers as Oracle or
> PostGIS?
> thank you in advance.
> MartinOuellet
> mapserver-users at lists.osgeo.org
