[mapserver-users] label placement problem
Raivo Alla
snaperski at gmail.com
Wed Apr 13 06:33:13 EDT 2011
Thank You !
The situation is illustrated here:
https://picasaweb.google.com/105062450878416453583/Ort#5595010970050628162
I got three different streets that have same label "2", and I would like to
display the labels so that for the same street address points
I could use declaration like MINDISTANCE 40, but if the same label "2"
appears on the address point that belongs to other street, then
it will not use MINDISTANCE and should display that label.
I have shapefile, whre one attribute "REFERENCEPOINT" holds the same
numerical value for the same address points (ie those
points which have label "2" on the screenshot and belong to the same street
have same "REFERENCEPOINT" value). Can I
somehow use it to render them differently?
I hope I expressed myself correctly :)
With regards,
Raivo
On Tue, Apr 12, 2011 at 1:18 AM, Lime, Steve D (DNR) <steve.lime at state.mn.us
> wrote:
> Can you share some pictures that illustrate the issue?
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Raivo Alla
> *Sent:* Wednesday, April 06, 2011 6:34 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] label placement problem
> Hello!
> I am using MapServer 5.4 and right now I'm facing with label positioning
> problem.
> Any help solving that would really be appreciated.
> 1. I have lots of buildings address points... so for example if two nearby
> located buildings at the crossing of "Some_street" and "Some_other_street"
> have both same house numbers (for example "1") then the MINDISTANCE 30
> declaration will cancel one label out.
> 2. I cannot remove MINDISTANCE neither since in many cases I have large
> building complexes where multiple buildings share same address label.
> And I want mapfile to declare some distance between those addresses that
> logically will mark the same address object.
> 3. In my buildings_addresses (points) file I do have attribute, which I
> could use to separate those two kinds of duplicate labels,
> but MapServer doent seem to support rendering them differently in a such
> way.... Or am I wrong?
> My LABEL definition:
> LABEL
> TYPE truetype
> ANTIALIAS true
> FONT "arial"
> COLOR 50 50 50
> SIZE 9
> priority 1
> ANGLE [POORDENURK]
> MINDISTANCE 30
> OUTLINECOLOR 220 220 220
> POSITION cc
> BUFFER 2
> END
> Hope that there will be some kind of solution here.
> Sincerely,
> Raivo Alla
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110413/0c35ea39/attachment.html
