[mapserver-users] Re: msProcessProjection(): Projection library
error. no options in 'init' file
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Apr 14 14:34:54 EDT 2011
On 11-04-14 3:20 PM, myOpenLayersUName wrote:
> Thanks for your response Jeff. I'm guessing you responded before you received
> my followup post regarding the location of the epsg file.
Correct, glad you solved it!
Just as a side note, if you are an MS4W user on the windows platform,
you might not have noticed that it contains the environment variable
"PROJ_LIB" (which specifies the location of the epsg file) set in
Apache's httpd.conf. In any case that may be the answer to one of your
earlier questions.
Happy MapServ-ing! :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
