[mapserver-users] Mapserver and raster layers
Christopher Dedels
cdedels at gmail.com
Sat Apr 16 17:52:01 EDT 2011
gdalinfo output for my raster file is:
Driver: GTiff/GeoTIFF
Files: /tmp/image.tiff
Size is 800, 600
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-123.860031127930000,38.011638641357401)
Pixel Size = (0.033339290618897,0.026156539916992)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-123.8600311, 38.0116386) (123d51'36.11"W, 38d 0'41.90"N)
Lower Left (-123.8600311, 53.7055626) (123d51'36.11"W, 53d42'20.03"N)
Upper Right ( -97.1885986, 38.0116386) ( 97d11'18.96"W, 38d 0'41.90"N)
Lower Right ( -97.1885986, 53.7055626) ( 97d11'18.96"W, 53d42'20.03"N)
Center (-110.5243149, 45.8586006) (110d31'27.53"W, 45d51'30.96"N)
Band 1 Block=800x2 Type=Float32, ColorInterp=Gray
Regards,
Chris
On Sat, Apr 16, 2011 at 5:47 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> What does:
> gdalinfo /tmp/image.tif
> report?
> -Steve W
> On 4/16/2011 4:52 PM, Christopher Dedels wrote:
>> Hmmm...missed that one. But changing the units to dd still doesn't have
>> any effect.
>> I am using mapserver 4.8.1. DEBUG is not an option in this version.
>> mapserv -v produces the following output:
>> MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>> SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
>> My request uri is:
>> http://localhost/cgi-bin/mapserv?MAP=/tmp/mapNl7O7H.map&LAYERS=ALL&MODE=MAP
>> Size is 800, 600
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> Metadata:
>> AREA_OR_POINT=Area
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Regards,
>> Chris
>> On Sat, Apr 16, 2011 at 4:34 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>> On 4/16/2011 4:33 PM, Christopher Dedels wrote:
>> Thanks for the suggestion. I have tried it and it appears to
>> have no
>> effect.
>> Chris
>> On Sat, Apr 16, 2011 at 4:26 PM, Stephen Woodbridge
>> <mailto:woodbri at swoodbridge.com>>> wrote:
>> Try changing the layer status to default, ie:
>> STATUS DEFAULT
>> -Steve W
>> On 4/16/2011 2:22 PM, Christopher Dedels wrote:
>> I am having some problems adding a raster layer to my
>> map. The
>> image
>> produced by mapserver is blank. My mapfile is as follows:
>> MAP
>> SIZE 800 600
>> UNITS meters
>> This is a problem, Your UNITs are meters, but your extents and
>> projection are DD!
>> EXTENT -123.8600311 38.0116386 -97.1885986
>> 53.7055626
>> PROJECTION
>> "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
>> END
>> LAYER
>> NAME "grid"
>> TYPE RASTER
>> DATA "/tmp/image.tiff"
>> STATUS ON
>> PROJECTION
>> END
>> END
>> END
>> I have also noticed that changing the DATA path to a
>> file which
>> does not
>> exist in the filesystem (or is not a GDAL-supported file
>> format)
>> has no
>> effect on the rendered output and does not produce an
>> error message.
>> Can somebody help me where I am going wrong?
>> Thanks
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> <mailto:mapserver-users at lists.osgeo.org>>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> mapserver-users at lists.osgeo.org <mailto:
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110416/ea073bbe/attachment.html
