[mapserver-users] Re: [mapserver-dev] problem with mapserver
thomas bonfort thomas.bonfort at gmail.com
Thu Apr 21 12:22:25 EDT 2011
please keep the message on list.
this is usually the case if the font file (referenced from your
fontset) was corrupt or pointing to an incorrect location.
On Thu, Apr 21, 2011 at 17:57, Annabell Schelton Lima <aschelton at uci.cu> wrote:
> i tried it that before, but does not work, when i use type truetype in my object label my label layer does not show..any idea??
> ----- Mensaje original -----
> De: "thomas bonfort" <thomas.bonfort at gmail.com>
> Para: "Annabell Schelton Lima" <aschelton at uci.cu>
> CC: "MapserverList OSGEO" <mapserver-users at lists.osgeo.org>
> Enviados: Jueves, 21 de Abril 2011 17:47:23 GMT +01:00 Amsterdam / Berlín / Berna / Roma / Estocolmo / Viena
> Asunto: Re: [mapserver-dev] problem with mapserver
> forwarding this to the mapserver-users list where it belongs.
> you are setting TYPE bitmap, which does not support more than ascii characters.
> you must set TYPE TRUETYPE and SIZE 9 (an integer value, not tiny,
> medium, etc...)
> regards,
> thomas
> On Thu, Apr 21, 2011 at 16:35, Annabell Schelton Lima <aschelton at uci.cu> wrote:
>> hi, i have a  problem with encoding  labels and mapfile configuration..my data is already converted to UTF-8 format, stored in a postgres database, but the labels do not recognize the accents, this is my mapfile in the section label, i declare it like a new layer with annotations, but as a part of a layer with labelitem the result it´s the same...
>>                  LABEL
>>                        SIZE   medium
>>                        FONT arial
>>                        COLOR   0 0 0
>>                        POSITION  cl
>>                        TYPE  bitmap
>>                        ANTIALIAS TRUE
>>                        MINDISTANCE 300
>>                        #MINFEATURESIZE 200
>>                        ENCODING "UTF-8"
>>                        BUFFER 4
>>                        PARTIALS FALSE
>>            END
>>  Please, somebody help me, i really need resolve this soon...
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
