[mapserver-users] OUTPUTFORMAT svg
Tim Heuer
HeuerT at landcareresearch.co.nz
Wed Apr 27 01:32:58 EDT 2011
Thanks Nicol, but we already solved it. It was a configuration setting that we have used wrongly:
Commenting out
# "wms_getmap_formatlist" "image/svg+xml,image/png"
From the map file did the trick. Not sure why or what is wrong about that line...
Kind regards,
Tim-Hinnerk Heuer
Landcare Research, Palmerston North
-----Original Message-----
From: Nicol Hermann [mailto:mapserver at geoworld.de]
Sent: Wednesday, 27 April 2011 4:01 p.m.
To: Tim Heuer
Subject: Re: [mapserver-users] OUTPUTFORMAT svg
Hi Tim,
Is this link of any help?
http://mapserver.org/output/svg.html
I saw that you are using WMS requests.
The document states:
"WMS layers are not yet supported."
Not sure of the documentations is outdated as it is last updated in
December 2008.
Best regards
Nicol
Am Mittwoch, den 27.04.2011, 12:13 +1200 schrieb Tim Heuer:
> Hi List,
> For quite a few days I am now stuck on this problem, and since I
> haven’t found it with searching the web, here a question:
> We have a relatively complex setup here. 2 MapServer versions. One is
> the standard 5.6.6 and the other one, we got a SVN snapshot:
> $ svn info
> Path: .
> URL: https://svn.osgeo.org/mapserver/trunk/mapserver
> Repository Root: https://svn.osgeo.org/mapserver
> Repository UUID: 7532c77e-422f-0410-93f4-f0b67bdd69e2
> Revision: 10907
> Node Kind: directory
> Schedule: normal
> Last Changed Author: tbonfort
> Last Changed Rev: 10907
> Last Changed Date: 2011-01-26 06:07:46 +1300 (Wed, 26 Jan 2011)
> We use the “normal” release version for our mapping application in the
> browser and the “SVN” version for printing SVG output. We decided to
> do it this way, because that is how we got the best looking maps with
> help of the MapFish print module.
> We have 2 map files (more but irrelevant for this), one for the base
> map and one for science data. In both we have this:
> IMAGETYPE png
> OUTPUTFORMAT
> NAME "aggpng24"
> DRIVER AGG/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> FORMATOPTION "INTERLACE=OFF"
> END
> OUTPUTFORMAT
> NAME svg
> MIMETYPE "image/svg+xml"
> DRIVER CAIRO/SVG
> #FORMATOPTION "COMPRESSED_OUTPUT=TRUE"
> FORMATOPTION "FULL_RESOLUTION=TRUE"
> END
> WEB
> IMAGEPATH "/var/www/tmp/"
> IMAGEURL "/tmp/"
> END
> # layer definitions
> Our requests look like this:
> http://ourwmsserver/cgi-bin/mapserv.svn?BBOX=175.90352%2C-38.04814%
> 2C176.34756%
> 2C-37.560966&HEIGHT=1024&WIDTH=933&map_resolution=72&CLASS=1%2C2%2C3%
> 2C4%2C6%2C7%2C8&SERVICE=WMS&REQUEST=GetMap&MAP=%2Fopt%2Fmapserver%
> 2Fmapfiles%2Flri.map&TRANSPARENT=true&VERSION=1.1.1&FORMAT=image%2Fsvg
> %2Bxml&format_options=dpi%3A72&LAYERS=luc_main&SRS=EPSG%3A4326
> Result: SVG XML
> 2C176.34756%
> 2C-37.560966&HEIGHT=1024&WIDTH=933&TRANSPARENT=true&map_resolution=72&VERSION=1.1.1&FORMAT=image%2Fsvg%2Bxml&SERVICE=WMS&map=%2Fopt%2Fmapserver%2Fmapfiles%2Fscenz_topo_new.map&format_options=dpi%3A72&LAYERS=coastpoly&REQUEST=GetMap&STYLES=&SRS=EPSG%3A4326
> Result: PNG image
> We would like to get SVG output in both cases. The funny thing is that
> we’re using the same MapServer instance, there are no errors reported
> and in one case we get SVG output (as desired) and in the other case
> we get a PNG with every request. If we however request a JPG in that
> case, we get an error. I also looked at the GetCapabilities output and
> found image/svg+xml there, but it does not output that for us.
> Another thing I’ve tried is to change to
> OUTPUTFORMAT svg
> in which case we always get an SVG, even when requesting a PNG. A
> solution for us could be to define 2 .map files for each layer, but
> that would be a maintenance nightmare with the amount of .map files we
> have already. Also, it seems sensible to me that multiple
> OUTPUTFORMATs are allowed and it should really work.
> I realise, that the “SVN” version we are using might not be totally
> bug free. The problem is though, that our map files do not work with
> the MapServer 6.0 beta 5 version, because there were a lot of changes
> in the way map files are handled in version 6.
> We need to get this working ASAP, so any help or comments are greatly
> appreciated.
> Thank you!
> Kind regards,
> Tim-Hinnerk Heuer
> ______________________________________________________________________
> Please consider the environment before printing this email
> Warning: This electronic message together with any attachments is
> confidential. If you receive it in error: (i) you must not read, use,
> disclose, copy or retain it; (ii) please contact the sender
> immediately by reply email and then delete the emails.
> The views expressed in this email may not be those of Landcare
> Research New Zealand Limited. http://www.landcareresearch.co.nz
> mapserver-users at lists.osgeo.org
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
