[mapserver-users] Some issues with SLD and MapServer 6.0.0 Beta
RC1
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Apr 28 15:12:25 EDT 2011
Sorry I hit send with finishing the e-mail. I will through each items
tomorrow and report.
On 28/04/2011 3:10 PM, Yewondwossen Assefa wrote:
> On 28/04/2011 9:34 AM, Arnd Wippermann wrote:
>> Hi,
>> I'm interested in map styling with SLD and have tested it locally with
>> MapServer 6.0.0 Beta RC1 windows binaries from www.gisinternals.com.
>> I have created an online application to play with SLD and the different
>> MapServer versions.
>> http://gis.ibbeck.de/ginfo/apps/OLExamples/OL210/MapServer_SLD_World/MapServ
>> er_SLD_World.asp
>> There the below issues can be seen. For the online application I have
>> only
>> 6.0.0 Beta 7 available, but it is the same with RC1.
>> Most things work great and create a good looking output.
>> But some things doesn't work as expected.
>> 1.
>> It seems, that the output directory for debug is set static to
>> C:\Windows\Temp.
>> msApplySLD(): Map file after SLD was applied
>> C:\WINDOWS\TEMP\4db963c5_ab0_1._sld.map
>> IMGPATH or IMGURL is not take in account.
> Temporary files are now written into the tmp directory location. It
> depends on the platform but should respect the environment variables
> set on your platform regarding temporary paths. It is not hardcoded in
> Mapserver. Ticket http://trac.osgeo.org/mapserver/ticket/3354 has
> notes on this.
>> 2. fill external symbol
>> Polygon fill with external graphic is erratic. If I zoom in one level
>> i get
>> one tile (South America).
>> It creates a file
>> "http%3A%2F%2Fgis.ibbeck.de%2FOLClient%2FSLD%2Fsmileyface.png" in
>> C:\Windows\Temp.
>> 3. Continent, Continent_Else
>> Filter PropertyIsLike doesn't work. With 5.6.1 it is ok.
>> Expression from generated mapfile : EXPRESSION ("[Continent]" =~
>> /^Africa/)
>> 4. or_like_abcdef
>> Filter Or and PropertyIsLike doesn't work. With 5.6.1 only the last
>> entry of
>> PropertyIsLike are taken.
>> With Or and PropertyIsEqualTo all entries are taken in both versions.
>> Expression from generated mapfile (6 beta): EXPRESSION ( ("[country]" =~
>> /^A/) Or ( ("[country]" =~ /^B/) Or ( ("[country]" =~ /^C/) Or (
>> ("[country]" =~ /^D/) Or ( ("[country]" =~ /^E/) Or ("[country]" =~
>> /^F/))
>> msEvalExpression: Expression parser error. Failed to parse expression:
>> ("[country]" =~ /^A/) Or ...
>> With changing =* to ~* and / to " the mapfile works :
>> EXPRESSION ( ("[country]" ~* "^A") Or ( ("[country]" ~* "^B") Or ...
>> It seems, that in the generated mapfile is a wrong expression.
>> 5. symbol fill rotated
>> Polygon fill with rotated square looks interesting, but not as
>> expected. Try
>> with 5.6.1.
>> 6. fill solid
>> Polygon with solid fill without stroke shows thin lines of the borders.
>> Some other issues are likely not supported by MapServer, but would be
>> nice
>> to have them.
>> A.
>> Changing the hatch width with sld. see "group3, hatch" as it is possible
>> with mapfile class.
>> B.
>> UserStyles from applied SLD not supported in WMS Styles
>> C.
>> WMS request GetStyles creates only one userstyle with rules from the
>> different styles described in the mapfile. Should it not create
>> different
>> userstyles for each style described in the mapfile?
>> Regards,
>> Arnd
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
