[mapserver-users] what is the map scale value for an image with 5m
pixel
jk
jk.chen at sdl.usu.edu
Mon Aug 1 13:57:52 EDT 2011
I have a layer of images each is made of pixel size 5 meter. I'm wondering
what is the minscale/maxscale value I should put in to map server map file?
Also, I have a orginfo output that say this pixel size value of Pixel Size =
(0.019400225288651,-0.019400225288651) , what is the scale value for this
map?
Please pardon me for the almost-silly questions.
JK
Driver: GTiff/GeoTIFF
Files: overview32.tif
Size is 16000, 3552
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-242.967352309208710,90.009700112644310)
Pixel Size = (0.019400225288651,-0.019400225288651)
Metadata:
TIFFTAG_XRESOLUTION=72
TIFFTAG_YRESOLUTION=72
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -242.967, 90.010) (242d58'2.47"W, 90d 0'34.92"N)
Lower Left ( -242.967, 21.100) (242d58'2.47"W, 21d 6'0.36"N)
Upper Right ( 67.4362523, 90.0097001) ( 67d26'10.51"E, 90d 0'34.92"N)
Lower Right ( 67.4362523, 21.1000999) ( 67d26'10.51"E, 21d 6'0.36"N)
Center ( -87.7655500, 55.5549000) ( 87d45'55.98"W, 55d33'17.64"N)
Band 1 Block=16000x1 Type=Byte, ColorInterp=Red
Band 2 Block=16000x1 Type=Byte, ColorInterp=Green
Band 3 Block=16000x1 Type=Byte, ColorInterp=Blue
View this message in context: http://osgeo-org.1803224.n2.nabble.com/what-is-the-map-scale-value-for-an-image-with-5m-pixel-tp6641936p6641936.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
