[mapserver-users] building FastCGI on MapServer 6.0
Mukesh Subedee msubedee at yahoo.com
Mon Aug 1 17:53:13 EDT 2011
Frank,
In the meantime, while configuring FastCGI as mentioned in
http://mapserver.org/optimization/fastcgi.html#configuration , I added
LoadModule and AddHandler as mentioned in the link in httpd.conf file.
However, I am not sure where should I add the content in the step 3 (Set FastCGI processing information). Do you have any idea of that?
Thanks!
To: Mukesh Subedee <msubedee at yahoo.com>
Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Sent: Monday, August 1, 2011 12:41 PM
Subject: Re: [mapserver-users] building FastCGI on MapServer 6.0
Mukesh,
Reviewing maperror.c, it should issue SUPPORTS=FASTCGI if
-DUSE_FASTCGI was defined at compile time.  So I suppose you
either didn't do a clean build (and some stuff didn't get recompiled) or
you aren't running the executable you built.
Best regards,
On Mon, Aug 1, 2011 at 12:11 PM, Mukesh Subedee <msubedee at yahoo.com> wrote:
> Hi all,
> I am again posting my problem as I am still stuck in the same place.
> I am trying to install/configure FastCGI on MapServer 6.0 in Ubuntu 10.04
> machines. I installed both fcgi-2.4.0 and mod_fastcgi-2.4.6 as mentioned in
> http://mapserver.org/optimization/fastcgi.html#obtaining-the-necessary-software.
> I configured MapServer --with-fastcgi=/usr option and could see "FastCGI
> support: -DUSE_FASTCGI" in Support Libraries. I did make and check ./mapserv
> -v but could not find SUPPORTS=FASTCGI there. I am wondering if I did
> anything wrong as I just followed the link and I did not get any errors
> while compiling any of those softwares/packages.
> Thanks!
> Mukesh
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110801/013b5b04/attachment-0001.html
