[mapserver-users] how does mapserver determine shapefile encoding?
Carlos Ruiz boolean10001 at yahoo.com
Tue Aug 2 16:06:28 EDT 2011
Lars,
Looking at the shp2pgsql documentation, it is possible to specify the shape attributes encoding with the -W parameter.
IC Carlos Ruiz
From: Lars Lingner <gislars+list at googlemail.com>
To: "'mapserver-users at lists.osgeo.org'" <mapserver-users at lists.osgeo.org>
Sent: Tuesday, August 2, 2011 2:45 PM
Subject: [mapserver-users] how does mapserver determine shapefile encoding?
Hello,
I have a shapefile from which I don't really know the encoding. It might
be latin1 or ISO-8559-5. The good thing is, when MapServer is accessing
the shapefile, the labels are shown correct.
QGis is also displaying everything fine.
But when I try to convert with shp2pgsql or ogr I get only garbage back.
I tried different source encodings. Since I need the data to be in the
database I'm now trying to find out where the problem is.
I tried converting the data on different systems (Ubuntu, RedHat), with
postgis/shp2pgsql from repository as well as self compiled. Same
results. Also iconv and recode wasn't a help.
As I said QGis is displaying everything fine it fails in converting the
shapefile too. Opening the dbf in LibreOffice doesn't helped either.
Finally my (odd) questions are: Why does MapServer do everything right?
How is the encoding determined? Can I see somewhere which encoding is
used by MapServer?
Thanks in advance for any pointers.
Lars
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110802/f235c5fa/attachment-0001.html
