[mapserver-users] MapServer as WMS client - HTTPS CERTIFICATE
problem.
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Tue Aug 2 18:20:10 EDT 2011
All,
I did some more research on this. Forwarding on my own posting from the user list here to ask a question,
Couldn't the server certificate be added to the request process via a MAPFILE > METADATA field for inclusion in the requests, in lieu of adding it to the CURL cert request, or am I thinking about this backwards?
thanks
bobb
All,
Ok, got the debugging to spit out the actual request for a service, with the following CERT error ::
[Tue Aug 2 16:21:59 2011].998742 CGI Request 1 on process 14407
[Tue Aug 2 16:22:00 2011].23599 msHTTPExecuteRequests(): HTTP request error. HTTP: request failed with curl error code 60 (SSL certificate problem, ve
rify that the CA cert is OK. Details:
error:14090086:SSL routines:func(144):reason(134)) for https://xxx.xx.xxxxxx.xx/ArcGIS/services/StPaul/ParcelPolyWMSF/MapServer/WMSServer?LAYERS=0&
REQUEST=GetMap&SERVICE=WMS&FORMAT=image/png24&STYLES=&HEIGHT=331&VERSION=1.1.1&SRS=EPSG:202011&WIDTH=943&BBOX=577250.000302263,157778.662078316,581708.
889731801,159343.765366945&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
[Tue Aug 2 16:22:00 2011].23974 msDrawWMSLayerLow(): WMS server error. WMS GetMap request failed for layer 'Parcel Polygons' (Status -60: SSL certific
ate problem, verify that the CA cert is OK. Details:
error:14090086:SSL routines:func(144):reason(134)).
[Tue Aug 2 16:22:00 2011].23989 msDrawMap(): Layer 1 (Parcel Polygons), 0.000s
[Tue Aug 2 16:22:00 2011].24013 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Aug 2 16:22:00 2011].24026 msDrawMap() total time: 0.025s
[Tue Aug 2 16:22:00 2011].77595 msSaveImage() total time: 0.053s
[Tue Aug 2 16:22:00 2011].77691 mapserv request processing time (loadmap not incl.): 0.079s
[Tue Aug 2 16:22:00 2011].77701 msFreeMap(): freeing map at 0x7144b0.
Question, can this be handled in the MAPFILE somehow? I did verify that the request works, once it's sent, by pasting into a Browser that already accepted the certificate.
Thanks
bobb
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110802/a86a8b37/attachment.html
