[mapserver-users] MapServer as WMS client - HTTPS CERTIFICATE problem.
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Aug 3 09:45:50 EDT 2011
Thanks for mentioning that Jukka.  Yes in fact MS4W's Apache does point
to that certificate file
(http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#g-certificates-for-https-with-wms-wfs-servers).
If someone is testing this, it would be great to get feedback on this
for MS4W 3.0.3 on the MS4W mailing list.  If you notice anything that
needs changed please do report this there, or file a ticket in its bug
tracker, whatever you feel is easier for you.
Thanks.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-08-03 1:55 AM, Rahkonen Jukka wrote:
> Hi,
> With Windows MS4W is setting the path to local certificate file with environment variable CURL_CA_BUNDLE and by default it is \ms4w\Apache\conf\ca-bundle\cacert.pem with the setenv.bat
> Perhaps you can tell where your modified certificate bundle file is with a mapfile too, but I have not tried it.  I have just added new certificates into the default cacert.pem.
> I am not sure if it it possible to make Mapserver to pass on the --insecure parameter for curl to tell it trust anything without checking the certificate at all.
> Have you read already http://trac.osgeo.org/mapserver/ticket/3070?
> -Jukka Rahkonen-
