[mapserver-users] WFS Spatial Filter Problem
John Callahan
john.callahan at udel.edu
Fri Aug 5 09:04:32 EDT 2011
This thread may or may not help:
http://osgeo-org.1803224.n2.nabble.com/WFS-intersect-request-td6458533.html
I have not tried using AND compound filters. The following format does work
for me using the BBOX filter.
<ogc:BBOX>
<ogc:PropertyName>SHAPE</ogc:PropertyName>
<gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:26957">
<gml:lowerCorner>149081.76574899518 163078.62572595105</gml:lowerCorner>
<gml:upperCorner>205627.85303800018 194899.95291598293</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
- John
John Callahan, Research Scientist
Delaware Geological Survey
University of Delaware
URL: http://www.dgs.udel.edu
On Fri, Aug 5, 2011 at 7:02 AM, Bryan Hempen <bhempen at sciops.esa.int> wrote:
> The problem: I am trying to implement something similar to
> http://openlayers.org/dev/examples/wfs-spatial-filter.html with my own
> data served by MapServer through a WFS. I just changed some lines in the
> code to make it work with MapServer, so the code is almost equal to the code
> in the example at the moment. So far it's working fine UNTIL I drag the
> polygon to apply the spatial filter! According to the getCapabitilies the
> server should be able to handle the request:
> <ogc:Spatial_Capabilities>
> <ogc:Spatial_Operators>
> <ogc:Equals/>
> <ogc:Disjoint/>
> <ogc:Touches/>
> <ogc:Within/>
> <ogc:Overlaps/>
> <ogc:Crosses/>
> <ogc:Intersect/>
> <ogc:Contains/>
> <ogc:DWithin/>
> <ogc:BBOX/>
> </ogc:Spatial_Operators>
> </ogc:Spatial_Capabilities>
> Both WFS GetFeature requests are sent via HTTP POST. The first one that
> works (called on page load) looks like this:
> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs"<http://www.opengis.net/wfs>xmlns:xsi="http ://
> www.w3.org/2001/XMLSchema-instance" service="WFS" version="1.0.0"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"<http://www.opengis.net/wfshttp://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd>
> <wfs:Query typeName="omega">
> <ogc:Filter xmlns:ogc="http://www .opengis.net/ogc"<http://www%C2%A0.opengis.net/ogc>
> <ogc:BBOX>
> <ogc:PropertyName>msGeometry</ogc:PropertyName>
> <gml:Box xmlns:gml="http: //www.opengis.net/gml"<http:%C2%A0//www.opengis.net/gml>srsName="EPSG:4326">
> <gml:coordinates decimal="." cs="," ts="
> ">135.45,-47.425 157.95,-36.175</gml:coordinates>
> </gml:Box>
> </ogc:BBOX>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> The request not working looks like this:
> "http://www.w3.org/2001/XMLSchema-instance"<http://www.w3.org/2001/XMLSchema-instance>service="WFS" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wfs
> <wfs:Query xmlns:ms="http://mapserver.gis.umn.edu/mapserver"<http://mapserver.gis.umn.edu/mapserver>typeName="ms:omega">
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"<http://www.opengis.net/ogc>
> <ogc:And>
> <ogc:Intersects>
> <gml:Polygon xmlns:gml="http://www.opengis.net/gml"<http://www.opengis.net/gml>srsName="EPSG:4326">
> <gml:outerBoundaryIs>
> <gml:LinearRing>
> ">145.72880866081,-40.709423872828 145.83867194206,-42.752880904078
> 148.34355475456,-40.995068404078
> 145.72880866081,-40.709423872828</gml:coordinates>
> </gml:LinearRing>
> </gml:outerBoundaryIs>
> </gml:Polygon>
> </ogc:Intersects>
> <ogc:BBOX>
> <gml:Box xmlns:gml="http://www.opengis.net/gml"<http://www.opengis.net/gml>srsName="EPSG:4326">
> ">135.45,-47.40302734375 157.95,-36.15302734375</gml:coordinates>
> </gml:Box>
> </ogc:BBOX>
> </ogc:And>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> Does anyone have an idea? Any help is appreciated, I am stuck.
> The setup:
> - OS: Red Hat Enterprise Linux 5.4
> - PostgreSQL 8.2
> - PostGIS 1.3
> - MapServer 5.6.5
> - OpenLayers, one of the latest versions. ProxyHost set and working
> (calling the proxy.cgi shows OpenLayers website)
> Kind regards,
> Bryan
> This message and any attachments are intended for the use of the addressee or addressees only. The unauthorised disclosure,
> use, dissemination or copying (either in whole or in part) of its content is not permitted. If you received this message in
> error, please notify the sender and delete it from your system. Emails can be altered and their integrity cannot be guaranteed by
> the sender.
> Please consider the environment before printing this email.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110805/024e66a6/attachment.html
