[mapserver-users] WFS Spatial Filter Problem
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Aug 8 11:14:28 EDT 2011
Bryan,
Is it possible for you to provide a sample data/map/request that I can
try that would reproduce your problems? If that is the case, please send
it to me directly and I will test it with the latest MapServer and
possibly provide answers.
regards,
Assefa
On 08/08/2011 10:58 AM, Bryan Hempen wrote:
> Hi there!
> These are things that I've tried in the meantime:
> - Manually sending the request to the server, but without
> different results compared to using OpenLayers functions. Also
> trying to force the usage of the proxy.cgi by containing it in the
> URL, but didn't bring up different results.
> Thought about the solution as suggested by the John, but
> substituting a Polygon with a BBOX only works for rectangular
> Polygons! I need to be able to specify arbitrary
> Polygons/Shapes. I am sure the solution proposed by him will
> work,
> because it will be just a request just like the one that
> already works.
> Thought about trying a newer version of the MapServer.
> However, I run is the newest ms4w on my local machone and I
> remember that I had the same problem a few weeks ago.
> Furthermore, John had the same problem with MapServer 6.0.0,
> and since then nothing changed about WFS or filter encoding
> according to the release announcements.
> Thought sending a GET request instead of a POST request could
> solve the problem! They provided examples in the documentation
> with links, something they definitely wouldn't have done in
> case those examples wouldn't work! However, even
> GET
> requests didn't work! What is strange: Also got errors with
> code 500. Shouldn't the mapserver return some error message?
> I AM CONFUSED! Please heeeelp!
> Regards,
> Bryan
> On 05/08/2011 15:04, John Callahan wrote:
>> This thread may or may not help:
>> http://osgeo-org.1803224.n2.nabble.com/WFS-intersect-request-td6458533.html
>> I have not tried using AND compound filters. The following format
>> does work for me using the BBOX filter.
>> <ogc:BBOX>
>> <ogc:PropertyName>SHAPE</ogc:PropertyName>
>> <gml:Envelope xmlns:gml="http://www.opengis.net/gml"
>> srsName="EPSG:26957">
>> <gml:lowerCorner>149081.76574899518 163078.62572595105</gml:lowerCorner>
>> <gml:upperCorner>205627.85303800018 194899.95291598293</gml:upperCorner>
>> </gml:Envelope>
>> </ogc:BBOX>
>> - John
>> John Callahan, Research Scientist
>> Delaware Geological Survey
>> University of Delaware
>> URL: http://www.dgs.udel.edu
> This message and any attachments are intended for the use of the addressee or addressees only. The unauthorised disclosure,
> use, dissemination or copying (either in whole or in part) of its content is not permitted. If you received this message in
> error, please notify the sender and delete it from your system. Emails can be altered and their integrity cannot be guaranteed by
> the sender.
> Please consider the environment before printing this email.
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110808/ad82a512/attachment.html
