[mapserver-users] WFS Spatial Filter Problem
Kai Behncke Kai-Behncke at gmx.de
Mon Aug 8 11:27:15 EDT 2011
Hi Bryan,
....could you show how you send the request manually to the server?
Might it be possible to send by mail your geodata and your wfs_file?
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Mon, 08 Aug 2011 16:58:30 +0200
> Von: Bryan Hempen <bhempen at sciops.esa.int>
> An: John Callahan <john.callahan at udel.edu>
> CC: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] WFS Spatial Filter Problem
> Hi there!
> These are things that I've tried in the meantime:
> - Manually sending the request to the server, but without different
> results compared to using OpenLayers functions. Also trying to force the
> usage of the proxy.cgi by containing it in the URL, but didn't bring up
> different results.
> - Thought about the solution as suggested by the John, but substituting
> a Polygon with a BBOX only works for rectangular Polygons! I need to be
> able to specify arbitrary Polygons/Shapes. I am sure the solution
> proposed by him will work,
>   because it will be just a request just like the one that already works.
> - Thought about trying a newer version of the MapServer. However, I run
> is the newest ms4w on my local machone and I remember that I had the
> same problem a few weeks ago. Furthermore, John had the same problem
> with MapServer 6.0.0,
> and since then nothing changed about WFS or filter encoding according to
> the release announcements.
> - Thought sending a GET request instead of a POST request could solve
> the problem! They provided examples in the documentation with links,
> something they definitely wouldn't have done in case those examples
> wouldn't work! However, even
> GET requests didn't work! What is strange: Also got errors with code
> 500. Shouldn't the mapserver return some error message?
> I AM CONFUSED! Please heeeelp!
> Regards,
> Bryan
> On 05/08/2011 15:04, John Callahan wrote:
> > This thread may or may not help:
> http://osgeo-org.1803224.n2.nabble.com/WFS-intersect-request-td6458533.html
> > I have not tried using AND compound filters.  The following format
> > does work for me using the BBOX filter.
> > <ogc:BBOX>
> > <ogc:PropertyName>SHAPE</ogc:PropertyName>
> > <gml:Envelope xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:26957">
> > <gml:lowerCorner>149081.76574899518 163078.62572595105</gml:lowerCorner>
> > <gml:upperCorner>205627.85303800018 194899.95291598293</gml:upperCorner>
> > </gml:Envelope>
> > </ogc:BBOX>
> > - John
> > John Callahan, Research Scientist
> > Delaware Geological Survey
> > University of Delaware
> > URL: http://www.dgs.udel.edu
> This message and any attachments are intended for the use of the addressee
> or addressees only. The unauthorised disclosure,
> use, dissemination or copying (either in whole or in part) of its content
> is not permitted. If you received this message in
> error, please notify the sender and delete it from your system. Emails can
> be altered and their integrity cannot be guaranteed by
> the sender.
> Please consider the environment before printing this email.
Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
