[mapserver-users] ArcSDE, Win32 and truncated GetCapabilities
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Aug 9 07:58:12 EDT 2011
On 11-08-09 3:40 AM, Stephan Holl wrote:
> Ahh, I see. I will pull out a patch[1] and try to apply on trunk since I
> have a recent trunk build-env. Reading the ticket seems the exact same
> problem I am facing. Btw. GetFeatureInfo  also returns the famous 500
> Premature End of script... error.
> Probably related.
Hi Stephan,
Is this your own compiled version of MapServer?
If yes: I wonder if you could try your same tests with MS4W 3.0.3?  Does
the same issue occur?
If no: what package are you using?  Have you tried a different package
to see if it can be duplicated?
Thanks.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
