[mapserver-users] NAME limit of 20 characters
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 16 12:27:37 EDT 2011
Hi Bart,
I looked at this this morning when you reported it...and I also couldn't
find where this limit exists. I tested with a 100 character string and
didn't have a problem with 6.1-dev.
I have removed that limit text from the docs, and I've added a note
about spaces, special characters, and starting with numbers (see
http://www.mapserver.org/mapfile/layer.html).
Thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-08-16 8:57 AM, Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> I am bit confused about the 20 character limit for LAYER->NAME that the
> MAP file documentation suggests.
> NAME [string]
> Short name for this layer. Limit is 20 characters. This name is the
> link between the mapfile and web interfaces that refer to this name.
> They must be identical. The name should be unique, unless one layer
> replaces another at different scales. Use the GROUP option to
> associate layers with each other.
> Is this limit really true?
> If I read Steve Lime's reply here this should not be the case:
> http://osgeo-org.1803224.n2.nabble.com/Character-Limit-for-NAME-and-GROUP-td5922135.html
> TIA for any clarification.
> Best regards,
> Bart
