[mapserver-users] Web application error. Malformed template name
Fawcett, David (MPCA) david.fawcett at state.mn.us
Tue Aug 16 12:55:21 EDT 2011
Dara,
I am pretty sure that relative paths work for templates, but for testing purposes, try using the absolute path to the template.
David.
Sent: Tuesday, August 16, 2011 10:03 AM
To: Fawcett, David (MPCA); mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Web application error. Malformed template name
It is below.  I am running a web mapping site with GeoMoose(2.0) and MapServer(5.2.1), but I can't seem to find a way to figure out what I am doing wrong or why I am ending up with the error. Any help would be greatly appreciated.
Miigwech!
Dara
MAP
SIZE 1920 1920
MAXSIZE 10000
EXTENT -20614760.777156 1751325.1919492 -1927436.1053437 7915207.1517617
UNITS meters
SYMBOLSET "..\symbols\glifwc_symbol.sym"
FONTSET "..\fonts\fonts.list"
CONFIG  "MS_ERRORFILE" "d:/Logs/Mapserver/MapServerDEVELSITE.log"
OUTPUTFORMAT
 NAME 'agg/png'
 DRIVER AGG/PNG
 IMAGEMODE RGBA
 FORMATOPTION "TRANSPARENT=TRUE"
END
IMAGETYPE AGG/PNG
TRANSPARENT ON
IMAGECOLOR -1 -1 -1
DEBUG 3
############################### ---- LEGEND ---- ###############################
 LEGEND
   STATUS on
   TRANSPARENT on
 END
############################### ---- Map projection ---- ###############################
 PROJECTION
  "init=epsg:900913"
 END
############################### ---- LAYERS ---- ###############################
LAYER #  MN Ogaa Harvest LBS
    NAME "mn_ogaa_harvest_lbs"
    TYPE POLYGON
    CONNECTIONTYPE postgis
    CONNECTION "host=zzzzzzz user=zzzzzz password=zzzzzz dbname=zzzzzz"
    PROCESSING "CLOSE_CONNECTION=DEFER"
    DATA "the_geom900913 from inland.mn_ogaa_harvest_lbs_spatial using unique new_id using srid=900913"
    PROJECTION
        "init=epsg:900913"
    END
    METADATA
        "wms_title" "MN Ogaa Harvest Lakes"
    END
    CLASS
        NAME "MN Ogaa Harvest Lakes"
        STYLE
            SYMBOL 0
            SIZE 6
            OUTLINECOLOR -1 -1 -1
            COLOR 182 177 145
        END
        TEMPLATE "../identify/ogaa_harvest/mn_ogaa_harvest_lbs_identify.html"
    END
END # MN Ogaa Harvest LBS
END #map file
My HTML identify template used to display results is,
<!-- MapServer Template-->
<tbody>
<tr>
<th colspan="2">MN Ogaa Harvest in Pounds</th>
</tr>
<tr>
<td align="left">Lake:</td>
<td>[lake]</td>
</tr>
<tr>
<td align="left">2011 Harvest:</td>
<td>[_2011_harvest]</td>
</tr>
</tbody>
<tr><td colspan="2"><hr></td></tr>
----- Original Message -----
From: Fawcett, David (MPCA)<mailto:david.fawcett at state.mn.us>
To: Dara Olson<mailto:dolson at glifwc.org> ; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Sent: Tuesday, August 16, 2011 9:42 AM
Subject: RE: [mapserver-users] Web application error. Malformed template name
Dara,
Can you share the part of your mapfile that describes this layer?
David.
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Dara Olson
Sent: Tuesday, August 16, 2011 9:01 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Web application error. Malformed template name
Good morning. I am having some problems identifying a layer through MapServer and I seem to be stuck.
I have a flat table of harvest by waterbody by year by individual in PostgreSQL/PostGIS. I created a "temporary view" of the sum harvested by waterbody by year and joined in geometry which I then made into a crosstab so that each lake would be listed and columns across with harvest by year.  It draws successfully in my web mapping application (and view looks fine in postgres), but when I try to use the Identify feature on the website (Mapserver GET URL request) I get the following error in MapServer,
[Fri Aug 12 09:57:33 2011].687000 msReturnPage(): Web application error. Malformed template name ().
[Fri Aug 12 09:57:33 2011].703000 msQueryByPoint(): Search returned no results. No matching record(s) found.
Before doing the crosstab I was getting this error, but I assumed that it didn't like the multiple records linked to the same geometry and that's why I did the crosstab.  But still nothing works.
Does anyone have any idea of where to begin to debug?  Any help would be greatly appreciated.
Thanks!
Dara Olson, GLIFWC
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110816/53b8d756/attachment-0001.html
