AW: AW: [mapserver-users] WFS Spatial Filter Problem
Eichner, Andreas - SID-NLKM Andreas.Eichner at sid.sachsen.de
Wed Aug 17 08:06:48 EDT 2011
OK, now run the CGI on the command line and append the QUERY_STRING parameter carrying the request parameters:
$ /usr/lib/cgi-bin/mapserv QUERY_STRING='map=<your/mapfile.map>&service=WFS&request=GetCapabilities'
This should give you the capabilities document. If that works use your failing one. This should expectedly fail. If you can't guess right now what causes the crash you can now use gdb to locate the error if you compiled with the debug option enabled. Let us know when you find more detailes about the cause.
Regards
> -----Ursprüngliche Nachricht-----
> Von: Bryan Hempen [mailto:bhempen at sciops.esa.int]
> Gesendet: Mittwoch, 17. August 2011 11:55
> An: Eichner, Andreas - SID-NLKM
> Cc: mapserver-users at lists.osgeo.org
> Betreff: Re: AW: [mapserver-users] WFS Spatial Filter Problem
> Hey guys,
> my current status report. I have tried the following list of things:
> - as proposed by Andreas, used shp2img. Works perfectly fine!
> - as proposed by Julien, took a look at the Apache error log.
> Here is a
> small excerpt of what it shows:
> [Wed Aug 17 10:42:15 2011] [error] [client 10.68.180.121]
> 3c34000000-3c3403d000
> r-xp 00000000 fd:00 3123859
> /usr/lib64/libldap_r-2.3.so.0
> .2.31, referer: http://ssols02.esac.esa.int/psa/bhempen/tree.html
> 3c34a1c000-3c34a1d000
> rw-p 0001c000 fd:00 3118384
> /usr/lib64/libgeos_c.so.1.6.2
> Premature end
> of scrip
> t headers: mapserv, referer:
> In case it could be useful to see the whole log, please just tell me.
> Now, to wrap things up again adding some new insights by testing with
> different versions of the MapServer. This is what happened:
> When I try to use the WFS FE Spatial Filter Intersect with MapServer
> 5.6.5 on a PostGIS layer, it doesn't work and I get an Error 500.
> When, however, I use a WFS FE Spatial Filter like Intersect with
> MapServer 5.6.5 on a shapefile layer with the SAME data as
> the PostGIS
> layer contains, it works!
> When I try to use the WFS FE Spatial Filter BBOX with
> MapServer 5.6.5 on
> a PostGIS layer, it works!
> When I use a WFS FE non-spatial filter like PropertyIsEqualTo and/or
> combined with logical filters like AND or OR combined with the WFS FE
> Spatial Filter BBOX with MapServer 5.6.5 on a shapefile layer or a
> PostGIS layer with the the SAME data, it works!
> 6.0.1 on a PostGIS layer, sometimes no results are returned and
> sometimes only some. The results are not accurate.
> 6.0.1 on a shapefile layer, sometimes no results are returned and
> Spatial Filter BBOX with MapServer 6.0.1 on a shapefile layer or a
> PostGIS layer with the the SAME data, it seems to work, but I am not
> 100% sure.
> Therefore: No problem with Apache setup, mapfiles, data,
> client/requests. Should be a MapServer bug...
> Using the same PostGIS db and shapefile all the time and mapfiles
> modified as minimal as possible.
> Kind regards,
> Bryan
> On 10/08/2011 15:16, Eichner, Andreas - SID-NLKM wrote:
> > Hi,
> > HTTP error code 500 means: Internal Server error and is
> usually reported when the (F)CGI process dies. Probably a
> simple NULL pointer dereference due to a missing check which
> results in a segmentation fault... Ever tried the thing with
> shp2img? If this also segfaults try recompiling with debug
> enabled and run it trough gdb.
> > Greets.
> >> Von: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> >> von Bryan Hempen
> >> Gesendet: Mittwoch, 10. August 2011 14:35
> >> An: Fawcett, David (MPCA)
> >> Betreff: Re: [mapserver-users] WFS Spatial Filter Problem
> >> Hi David,
> >> I enabled debugging using the following settings:
> >>      CONFIG "MS_ERRORFILE" "/home/bhempen/ms_error.txt"
> >>      DEBUG 5
> >>      CONFIG "CPL_DEBUG" "ON"
> >>      CONFIG "PROJ_DEBUG" "ON"
> >> The only line that shows up after I got an error 500 using
> >> the spatial filter is:
> >> [Wed Aug 10 14:30:46 2011].451858 CGI Request 1 on process 21100
> >> Not really helpful, right?
> >> Regards,
> >> Bryan
> >> On 09/08/2011 15:38, Fawcett, David (MPCA) wrote:
> >> 	Bryan,
> >> 	For testing, I would enable debugging at the MAP or
> >> LAYER level.  If you set DEBUG 5, I think that you should be
> >> able to see the query that MapServer is crafting.
> >> 	More on debugging here:
> >> http://mapserver.org/optimization/debugging.html#debugging
> >> 	David.
> >> 	From: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> >> Bryan Hempen
> >> 	Sent: Tuesday, August 09, 2011 4:15 AM
> >> 	Subject: Re: [mapserver-users] WFS Spatial Filter Problem
> >> 	Dear Kai and Assefa,
> >> 	After you two guys requested me to send you my setup, I
> >> exported the content in the databasetable to a shapefile so
> >> you can test it. When I tested the spatial filter right after
> >> that, it suddenly worked ! This narrows down the possibilities:
> >> 	- The request I send is definitely not the problem
> >> anymore. It works with MapServer + shapefile and with GeoServer.
> >> 	- I exported only the geometries to the shapefile in
> >> the table with geometrytype = POLYGON because from ~8000
> >> geometries ~10 are linestrings. So I investigated possible
> >> problems with the linestring geometries by telling the
> >> MapServer not to serve them using a subquery in the mapfile:
> >> 	DATA "the_geom from (select * from alldata where
> >> geometrytype(the_geom) = 'POLYGON') as subquery using unique
> >> product_id using SRID=4326"
> >> 	Error 500 still occured. Therefore, the data can't be
> >> the problem neither, right?
> >> 	- Since I didn't change anything else MapServer must
> >> have problems communicating with the PostGIS database, but
> >> why Error 500 then?
> >> 	Here is my mapfile:
> >> 	MAP
> >> 	    NAME "WFS Server"
> >> 	    STATUS ON
> >> 	    SIZE 600 400
> >> 	    SYMBOLSET
> >> "/var/www/html/psa/bhempen/mapservertest/symbols/symbols.sym"
> >> 	    EXTENT -180 -90 180 90
> >> 	    UNITS DD
> >> 	    SHAPEPATH "/var/www/html/psa/bhempen/mapservertest/data/"
> >> 	    IMAGECOLOR 255 255 255
> >> 	    FONTSET
> >> "/var/www/html/psa/bhempen/mapservertest/fonts/fonts.list"
> >> 	    MAXSIZE 4096 # needs to be set because otherwise an
> >> error will appear when rendering images on large screens
> >> 	#IMAGECOLOR     200 200 200 #commented out for WFS
> >> 	PROJECTION
> >> 	       'init=epsg:4326'
> >> 	END
> >> 	    WEB
> >> 	    TEMPLATE
> >> '/var/www/html/psa/bhempen/mapservertest/template.html'
> >> 	    IMAGEPATH '/var/www/html/psa/bhempen/tmp/'
> >> 	    IMAGEURL  '/psa/bhempen/tmp/'
> >> 	      METADATA
> >> 	            "wfs_title"                  "WFS Demo
> >> Server for MapServer" ## REQUIRED
> >> 	            "wfs_onlineresource"
> >> "http://localhost/cgi-bin/psa/mapserv?map=/home/bhempen/wfs.ma
> >> p&"
> >> <http://localhost/cgi-bin/psa/mapserv?map=/home/bhempen/wfs.ma
> >> p&>   ## Recommended
> >> 	            "wfs_srs"                    "EPSG:4326" ##
> >> Recommended
> >> 	            "wfs_abstract"               "This text
> >> describes my WFS service." ## Recommended
> >> 	      END
> >> 	    END
> >> 	LAYER
> >> 	    NAME   "omega"
> >> 	    STATUS       DEFAULT
> >> 	    TYPE         POLYGON
> >> 	    METADATA
> >> 	        "wfs_title"             "omega footprints" ##REQUIRED
> >> 	        "wfs_srs"               "EPSG:4326" ## REQUIRED
> >> 	       "gml_include_items"     "all" ## Optional
> >> (serves all attributes for layer)
> >> 	        "gml_featureid"         "product_id" ## REQUIRED
> >> 	    END
> >> 	    PROJECTION
> >> 	        "init=epsg:4326"
> >> 	    END
> >> 	    CONNECTIONTYPE POSTGIS
> >> 	    CONNECTION "host=localhost port=xxx dbname=xxx
> >> user=xxx password=xxx"
> >> 	    DATA "the_geom from alldata using unique product_id
> >> using SRID=4326"
> >> 	    CLASS
> >> 	        STYLE
> >> 	            OUTLINECOLOR    125 0 0
> >> 	        END
> >> 	    END
> >> 	    DUMP TRUE             ## REQUIRED
> >> 	END # layer
> >> 	END
> >> 	Does anyone see a problem with the setup?
> >> 	Many thanks to Kai and Assefa for the help so far! I am
> >> going to send you the shapefile (which you could import into
> >> the database with pgsql2shp), the mapfile, and my client.
> >> 	Kind regards,
> >> 	Bryan
> >> 	This message and any attachments are intended for the
> >> use of the addressee or addressees only. The unauthorised
> disclosure,
> >> 	use, dissemination or copying (either in whole or in
> >> part) of its content is not permitted. If you received this
> >> message in
> >> 	error, please notify the sender and delete it from your
> >> system. Emails can be altered and their integrity cannot be
> >> guaranteed by
> >> 	the sender.
> >> 	Please consider the environment before printing this email.
> >> This message and any attachments are intended for the use of
> >> the addressee or addressees only. The unauthorised disclosure,
> >> use, dissemination or copying (either in whole or in part) of
> >> its content is not permitted. If you received this message in
> >> guaranteed by
> >> the sender.
> guaranteed by
> the sender.
