[mapserver-users] Invalid pdf file from WMS
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Wed Aug 17 15:36:59 EDT 2011
Command with big BBOX does lead into segmantation fault.  Unfortunately I am just an amateur and I have no idea about what is a backtrace and how I could provide it to you. The server is a virtual Linux box (Ubuntu).
-Jukka Rahkonen-
thomas bonfort wrote:
> the second one is incomplete, the request seems to be failing.
> can you run the request locally to see if it segfaults, and if so
provide a backtrace:
> /path/to/mapserver-cgi
QUERY_STRING='map=/path/to/map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&SRS=EPSG:2393&STYLES='
thomas
On Wed, Aug 17, 2011 at 15:40, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
>> This request from Mapserver 6.0 gives me a nice pdf file:
>> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&SRS=EPSG:2393&STYLES=
> However, if I double the bounding box the resulting pdf cannot be opened by Acrobat reader.
> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1728&HEIGHT=1324&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&SRS=EPSG:2393&STYLES=
> The latter gives fine image with format=image/png. Any idea about what is going wrong?
> -Jukka Rahkonen-_______________________________________________
> mapserver-users at lists.osgeo.org
