[mapserver-users] Problem GetFeature with geom filter on WFS
Stéphane Brunner
stephane.brunner at camptocamp.com
Thu Aug 18 11:49:50 EDT 2011
Hello Steve,
Sorry for the delay. I as on holiday last couple of weeks but the
issue is still a blocker for us.
Your say « PostGIS should be returning an appropriate set of candidate
features » but with our request PostGIS returns only the 100 first
features (a subset of all features) without taking any geographical
aspect into account. MapServer filters them correctly but as we get
only the 100 first results from the DB, we miss many objects and/or
they are not related to the area where we want to apply a geographical
filter. We've done a test on how MapServer handles the 100 first
results and it's working.
We also tested the behavior with a SHP file and it works like a charm,
there is no limitation. For our understanding, there is an issue in
the way mapserver pass the query to PostGIS as there is an
inappropriate LIMIT value in the SQL statement and mapserver doesn't
seem to pass a BBOX in order to prefilter the set in the DB.
Best regards
Stéphane Brunner
2011/7/30 Steve Lime <sdlime at gmail.com>:
> The filter encoding code only translates certain things into native SQL, the rest is handled in a uniform way within MapServer. Hopefully this will change over time and more processing will be moved to the database but there hasn't been time to do that yet, maybe for 6.2.
> PostGIS should be returning an appropriate set of candidate features for MapServer to perform additional filtering. Shapefiles work the same way. If you look at the SQL executed by Postgres you should see all of the matching features plus a few more.
> Steve
> Sent from my iPad
> On Jul 28, 2011, at 9:18 AM, Stéphane Brunner <stephane.brunner at camptocamp.com> wrote:
>> Hello,
>> I log the sql request on spatial filter and I have this:
>> select "oid","nummer","gemeinde","gueltigkeit","flgrundb","quote","eigentuemer","adresse_lang",encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex')
>> as geom,"oid" from (SELECT oid, t1.geom, t1.nummer, t2.gemeinde,
>> t1.gueltigkeit1_txt as gueltigkeit, t2.flgrundb, ((t2.zaehler::text ||
>> '/'::text) || t2.nenner::text) AS quote, t2.eigentuemer,
>> (((t2.adresse::text || ', '::text) || t2.plz::text) || ' '::text) ||
>> t2.ort::text AS adresse_lang FROM av.liegenschaften_liegenschaft_area
>> as t1, av.view_gemlis_geomaste_parzelle as t2 WHERE t1.gdid = t2.gdeid
>> and t1.nummer = t2.parznr::text) AS foo where geom &&
>> GeomFromText('POLYGON((620000 218000,620000 278000,690000
>> 278000,690000 218000,620000 218000))',-1) limit 100
>> I didn't see any postggis filter than I try to do a spatial filter on
>> one of the 100 first results
>> Than I have a correct result ...
>> Than why mapserver doesn't use postgis spatial filter ? Does I miss something ?
>> Thank-you in advance
>> Stéphane Brunner
>> 2011/7/26 Stéphane Brunner <stephane.brunner at camptocamp.com>:
>>> Hello,
>>> I just test it with a shape file, and it's working...
>>> I will investigate a little bit more to know why it's not working with postgres.
>>> Sincerely
>>> Stéphane Brunner
>>> 2011/7/25 Steve Lime <sdlime at gmail.com>:
>>>> Never mind on version, I saw 6.0.0 in the response... ;-) Steve
>>>> On Mon, Jul 25, 2011 at 6:19 AM, Stéphane Brunner
>>>>> Hello,
>>>>> I have the mapfile [0]. when I done a GetFeature on the nummer [1] I
>>>>> have 4 results [2] (with duplicate but it's an other issue).
>>>>> When I done a spatial filter [3] I have no results [4] but I should
>>>>> have at least one result ...
>>>>> Thanks in advance for having a look on this issue.
>>>>> Sincerely yours
>>>>> Stéphane Brunner
>>>>> Following: specified, GetCapabilities [5], describefeaturetype [6].
>>>>> mapfile [0]:
>>>>> MAP
>>>>> NAME "map"
>>>>> EXTENT 620000 218000 690000 278000
>>>>> UNITS METERS
>>>>> IMAGETYPE jpeg
>>>>> RESOLUTION 72
>>>>> DEFRESOLUTION 72
>>>>> IMAGECOLOR 255 255 255
>>>>> STATUS ON
>>>>> FONTSET "fonts.conf"
>>>>> SYMBOLSET "symbole.sym"
>>>>> MAXSIZE 5000
>>>>> PROJECTION
>>>>> "init=epsg:21781"
>>>>> END
>>>>> # Used by overlays
>>>>> OUTPUTFORMAT
>>>>> NAME png256
>>>>> DRIVER AGG/PNG
>>>>> MIMETYPE "image/png256"
>>>>> IMAGEMODE RGBA
>>>>> EXTENSION "png"
>>>>> FORMATOPTION "INTERLACE=OFF"
>>>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>>>> FORMATOPTION "QUANTIZE_COLORS=256"
>>>>> END
>>>>> OUTPUTFORMAT
>>>>> NAME png
>>>>> DRIVER AGG/PNG
>>>>> MIMETYPE "image/png"
>>>>> IMAGEMODE RGBA
>>>>> EXTENSION "png"
>>>>> END
>>>>> WEB
>>>>> METADATA
>>>>> "ows_title" "map"
>>>>> "ows_srs" "epsg:21781"
>>>>> "ows_encoding" "UTF-8"
>>>>> "wms_feature_info_mime_type" "application/vnd.ogc.gml"
>>>>> "wms_enable_request" "*"
>>>>> "ows_enable_request" "*"
>>>>> "gml_include_items" "all"
>>>>> "gml_featureid" "id"
>>>>> "wfs_title" "map"
>>>>> "wfs_srs" "epsg:21781"
>>>>> END
>>>>> IMAGEPATH '/var/tmp/'
>>>>> END
>>>>> LEGEND
>>>>> IMAGECOLOR 240 240 240
>>>>> LABEL
>>>>> FONT arial
>>>>> ANTIALIAS true
>>>>> TYPE truetype
>>>>> SIZE 9
>>>>> COLOR 0 0 0
>>>>> END
>>>>> END
>>>>> LAYER
>>>>> NAME "Liegenschaft_Query"
>>>>> TYPE POLYGON
>>>>> STATUS ON
>>>>> TEMPLATE fooOnlyForWMSGetFeatureInfo
>>>>> CONNECTIONTYPE postgis
>>>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>>>> CONNECTION "user=www-data password=www-data dbname=dev host=localhost"
>>>>> DATA "geom from (SELECT oid, t1.geom, t1.nummer FROM
>>>>> av.view_i_liegenschaft_all AS t1) AS foo using unique oid using
>>>>> SRID=-1"
>>>>> # GROUP "TOPIC_Liegenschaften_LN"
>>>>> METADATA
>>>>> "ows_title" "Liegenschaft_Query"
>>>>> "id_attribute_string" "oid"
>>>>> "ows_featureid" "oid"
>>>>> "ows_geometries" "geom"
>>>>> "ows_geom_type" "polygon"
>>>>> "query_returned_attributes" "nummer"
>>>>> "gml_include_items" "oid,nummer,geom"
>>>>> "gml_geometries" "geom"
>>>>> "gml_geom_type" "polygon"
>>>>> "gml_nummer_type" "Character"
>>>>> #"gml_groups" "TOPIC_Liegenschaften_LN"
>>>>> "gml_featureid" "oid"
>>>>> "wfs_title" "Liegenschaft_Query"
>>>>> END
>>>>> DUMP TRUE
>>>>> PROJECTION
>>>>> "init=epsg:21781"
>>>>> END
>>>>> CLASS
>>>>> NAME "Liegenschaft"
>>>>> STYLE
>>>>> SYMBOL "circle"
>>>>> SIZE 3
>>>>> OUTLINECOLOR 0 0 0
>>>>> END
>>>>> END
>>>>> END
>>>>> END
>>>>> query on the nummer [1]:
>>>>> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
>>>>> version="1.0.0" maxFeatures="100"
>>>>> xsi:schemaLocation="http://www.opengis.net/wfs
>>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>>>>> <wfs:Query typeName="feature:Liegenschaft_Query"
>>>>> xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
>>>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>>>> <ogc:PropertyIsEqualTo>
>>>>> <ogc:PropertyName>nummer</ogc:PropertyName>
>>>>> <ogc:Literal>3634</ogc:Literal>
>>>>> </ogc:PropertyIsEqualTo>
>>>>> </ogc:Filter>
>>>>> </wfs:Query>
>>>>> </wfs:GetFeature>
>>>>> response on the nummer [2]:
>>>>> <?xml version='1.0' encoding="UTF-8" ?>
>>>>> <wfs:FeatureCollection
>>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>>> xmlns:gml="http://www.opengis.net/gml"
>>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>>>>> http://c2cpc89.camptocamp.com/sbrunner/mapserv?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=feature:Liegenschaft_Query&OUTPUTFORMAT=XMLSCHEMA">
>>>>> <gml:boundedBy>
>>>>> <gml:Box srsName="EPSG:21781">
>>>>> <gml:coordinates>661054.808000,244611.321000
>>>>> 663053.704000,244888.622000</gml:coordinates>
>>>>> </gml:Box>
>>>>> </gml:boundedBy>
>>>>> <gml:featureMember>
>>>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2380997">
>>>>> <gml:boundedBy>
>>>>> <gml:coordinates>661054.808000,244854.251000
>>>>> 661088.687000,244888.622000</gml:coordinates>
>>>>> </gml:Box>
>>>>> </gml:boundedBy>
>>>>> <ms:geom>
>>>>> <gml:Polygon srsName="EPSG:21781">
>>>>> <gml:outerBoundaryIs>
>>>>> <gml:LinearRing>
>>>>> <gml:coordinates>661076.579000,244888.622000
>>>>> 661054.808000,244875.484000 661062.744000,244858.448000
>>>>> 661064.653000,244854.251000 661088.687000,244869.173000
>>>>> 661076.579000,244888.622000 </gml:coordinates>
>>>>> </gml:LinearRing>
>>>>> </gml:outerBoundaryIs>
>>>>> </gml:Polygon>
>>>>> </ms:geom>
>>>>> <ms:oid>2380997</ms:oid>
>>>>> <ms:nummer>3634</ms:nummer>
>>>>> </ms:Liegenschaft_Query>
>>>>> </gml:featureMember>
>>>>> <gml:featureMember>
>>>>> <gml:boundedBy>
>>>>> </gml:Box>
>>>>> </gml:boundedBy>
>>>>> <ms:geom>
>>>>> <gml:LinearRing>
>>>>> </gml:LinearRing>
>>>>> </gml:Polygon>
>>>>> </ms:geom>
>>>>> <gml:featureMember>
>>>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2384539">
>>>>> <gml:boundedBy>
>>>>> <gml:coordinates>663017.565000,244611.321000
>>>>> 663053.704000,244650.084000</gml:coordinates>
>>>>> </gml:Box>
>>>>> </gml:boundedBy>
>>>>> <ms:geom>
>>>>> <gml:LinearRing>
>>>>> <gml:coordinates>663017.565000,244635.722000
>>>>> 663033.235000,244611.321000 663045.949000,244619.485000
>>>>> 663053.704000,244626.417000 663034.337000,244650.084000
>>>>> 663017.565000,244635.722000 </gml:coordinates>
>>>>> </gml:LinearRing>
>>>>> </gml:Polygon>
>>>>> </ms:geom>
>>>>> <ms:oid>2384539</ms:oid>
>>>>> <gml:featureMember>
>>>>> <gml:boundedBy>
>>>>> </gml:Box>
>>>>> </gml:boundedBy>
>>>>> <ms:geom>
>>>>> <gml:LinearRing>
>>>>> </gml:LinearRing>
>>>>> </gml:Polygon>
>>>>> </ms:geom>
>>>>> </wfs:FeatureCollection>
>>>>> query with spatial filter [3]:
>>>>> <ogc:Intersects>
>>>>> <ogc:PropertyName>geom</ogc:PropertyName>
>>>>> <gml:Point xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:21781">
>>>>> <gml:coordinates decimal="." cs="," ts="
>>>>> ">661070.024,244872.084</gml:coordinates>
>>>>> </gml:Point>
>>>>> </ogc:Intersects>
>>>>> </ogc:Filter>
>>>>> </wfs:Query>
>>>>> </wfs:GetFeature>
>>>>> response with spatial filter [4]:
>>>>> <gml:boundedBy>
>>>>> <gml:null>missing</gml:null>
>>>>> </gml:boundedBy>
>>>>> GetCapabilities [5]:
>>>>> <WFS_Capabilities
>>>>> version="1.0.0"
>>>>> updateSequence="0"
>>>>> xmlns="http://www.opengis.net/wfs"
>>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
>>>>> <!-- MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>>>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL
>>>>> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>>>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>>>> INPUT=SHAPEFILE -->
>>>>> <Service>
>>>>> <Name>MapServer WFS</Name>
>>>>> <Title>Amtliche Vermessung</Title>
>>>>> <Abstract>Die amtliche Vermessung nach DM01 Darstellung als WMS
>>>>> Dienst für MapFish Projekte</Abstract>
>>>>> <OnlineResource>http://c2cpc89.camptocamp.com/sbrunner/mapserv?</OnlineResource>
>>>>> </Service>
>>>>> <Capability>
>>>>> <Request>
>>>>> <GetCapabilities>
>>>>> <DCPType>
>>>>> <HTTP>
>>>>> <Get
>>>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?"
>>>>> </HTTP>
>>>>> </DCPType>
>>>>> <DCPType>
>>>>> <HTTP>
>>>>> <Post
>>>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?" />
>>>>> </HTTP>
>>>>> </DCPType>
>>>>> </GetCapabilities>
>>>>> <DescribeFeatureType>
>>>>> <SchemaDescriptionLanguage>
>>>>> <XMLSCHEMA/>
>>>>> </SchemaDescriptionLanguage>
>>>>> <DCPType>
>>>>> <HTTP>
>>>>> <Get
>>>>> </HTTP>
>>>>> </DCPType>
>>>>> <DCPType>
>>>>> <HTTP>
>>>>> <Post
>>>>> </HTTP>
>>>>> </DCPType>
>>>>> </DescribeFeatureType>
>>>>> <GetFeature>
>>>>> <ResultFormat>
>>>>> <GML2/>
>>>>> </ResultFormat>
>>>>> <DCPType>
>>>>> <HTTP>
>>>>> <Get
>>>>> </HTTP>
>>>>> </DCPType>
>>>>> <DCPType>
>>>>> <HTTP>
>>>>> <Post
>>>>> </HTTP>
>>>>> </DCPType>
>>>>> </GetFeature>
>>>>> </Request>
>>>>> </Capability>
>>>>> <FeatureTypeList>
>>>>> <Operations>
>>>>> <Query/>
>>>>> </Operations>
>>>>> <FeatureType>
>>>>> <Name>Liegenschaft_Query</Name>
>>>>> <Title>Liegenschaft_Query</Title>
>>>>> <SRS>epsg:21781</SRS>
>>>>> <LatLongBoundingBox minx="620000" miny="218000" maxx="690000"
>>>>> maxy="278000" />
>>>>> </FeatureType>
>>>>> <FeatureType>
>>>>> <Name>Liegenschaft_Query_ALL</Name>
>>>>> <Title>Liegenschaft_Query_ALL</Title>
>>>>> maxy="278000" />
>>>>> </FeatureType>
>>>>> </FeatureTypeList>
>>>>> <ogc:Filter_Capabilities>
>>>>> <ogc:Spatial_Capabilities>
>>>>> <ogc:Spatial_Operators>
>>>>> <ogc:Equals/>
>>>>> <ogc:Disjoint/>
>>>>> <ogc:Touches/>
>>>>> <ogc:Within/>
>>>>> <ogc:Overlaps/>
>>>>> <ogc:Crosses/>
>>>>> <ogc:Intersect/>
>>>>> <ogc:Contains/>
>>>>> <ogc:DWithin/>
>>>>> <ogc:BBOX/>
>>>>> </ogc:Spatial_Operators>
>>>>> </ogc:Spatial_Capabilities>
>>>>> <ogc:Scalar_Capabilities>
>>>>> <ogc:Logical_Operators />
>>>>> <ogc:Comparison_Operators>
>>>>> <ogc:Simple_Comparisons />
>>>>> <ogc:Like />
>>>>> <ogc:Between />
>>>>> </ogc:Comparison_Operators>
>>>>> </ogc:Scalar_Capabilities>
>>>>> </ogc:Filter_Capabilities>
>>>>> </WFS_Capabilities>
>>>>> describefeaturetype [6]:
>>>>> <schema
>>>>> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
>>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>>>> xmlns="http://www.w3.org/2001/XMLSchema"
>>>>> elementFormDefault="qualified" version="0.1" >
>>>>> <import namespace="http://www.opengis.net/gml"
>>>>> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"
>>>>> <element name="Liegenschaft_Query"
>>>>> type="ms:Liegenschaft_QueryType"
>>>>> substitutionGroup="gml:_Feature" />
>>>>> <complexType name="Liegenschaft_QueryType">
>>>>> <complexContent>
>>>>> <extension base="gml:AbstractFeatureType">
>>>>> <sequence>
>>>>> <element name="geom" type="gml:PolygonPropertyType"
>>>>> minOccurs="0" maxOccurs="1"/>
>>>>> <element name="oid" type="string"/>
>>>>> <element name="nummer" type="Character"/>
>>>>> </sequence>
>>>>> </extension>
>>>>> </complexContent>
>>>>> </complexType>
>>>>> </schema>
>>>>> camptocamp.com
>>>>> mapfish.org
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> camptocamp.com
>>> mapfish.org
>> camptocamp.com
>> mapfish.org
camptocamp.com
mapfish.org
