[mapserver-users] Java Crash
Thiago Tiedtke dos Reis tiedtke at gmail.com
Thu Aug 18 18:50:37 EDT 2011
Hi Stuart,
I don't know if are related problems ... This same problem happens with me,
when I trying to build a extension for Tcl without a little patch.
After the patch, the method getBytes then works fine for me...see:
http://trac.osgeo.org/mapserver/ticket/1533
Good lucky!
2011/8/18 <Stuart.Harlan at modot.mo.gov>
> I compiled MapServer 6.0.1 on Windows, with threads, and removed the
> components marked "unsafe".  I also built the Java Mapscript component,
> targeting the 1.5 JVM.  I can generate a map image, and save it to a file
> using the Java method "imageObj.save(filename, map)".  However, when I try
> to call "imageObj.getBytes", the JVM crashes.  Any ideas?  Thanks.
> Stuart Harlan
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110818/4f79f4c0/attachment.html
