[mapserver-users] Invalid pdf file from WMS
Worth Lutz
wal3 at mindspring.com
Thu Aug 18 19:43:57 EDT 2011
I can get php MapScript to segfault drawing PDF maps when the same PNG map
works fine. I had to crank up the allowed memory and allowed time in PHP to
get my maps to work. I will submit a bug report and test case when I
understand the problem better. I am trying to develop a method of creating
a large set of PDF maps dynamically with PHP and and am finally figuring it
out.
Worth Lutz
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Thursday, August 18, 2011 3:11 AM
To: Rahkonen Jukka
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Invalid pdf file from WMS
this seems to be a cairo/pdf issue, as the cairo/png works fine:
http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSIO
N=1.1.1&WIDTH=1728&HEIGHT=1324&LAYERS=default&TRANSPARENT=TRUE&FORMAT=cairop
ng&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097
395&SRS=EPSG:2393&STYLES=
what cairo version are you using? can you upgrade it?
thomas
On Wed, Aug 17, 2011 at 22:46, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
wrote:
> Hi,
> Amazing. I got this
> (gdb) bt
> #0 0x0013a258 in FT_Done_Face () from /usr/lib/libfreetype.so.6
> #1 0x00f447c3 in ?? () from /usr/lib/libcairo.so.2
> #2 0x00f4ba19 in cairo_font_face_destroy () from /usr/lib/libcairo.so.2
> #3 0x0813a8b4 in ?? ()
> #4 0x0813a9c8 in cleanupCairo ()
> #5 0x080c5aee in ?? ()
> #6 0x0810b406 in ?? ()
> #7 0x0807207d in ?? ()
> #8 0x0805c2f4 in ?? ()
> #9 0x00fefbd6 in __libc_start_main () from /lib/tls/i686/cmov/libc.so.6
> #10 0x08057881 in ?? ()
> -Jukka-
> ________________________________________
> Lähettäjä: thomas bonfort [thomas.bonfort at gmail.com]
> Lähetetty: 17. elokuuta 2011 22:56
> Vastaanottaja: Rahkonen Jukka
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Invalid pdf file from WMS
> if gdb is installed on the system, you do:
> gdb /path/to/mapserv
> $ run QUERY_STRING='map=...&....'
> (...program runs and spits out the beginning of the pdf..., then
segfaults)
> $ bt
> thomas
> On Wed, Aug 17, 2011 at 21:36, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
wrote:
>> Hi,
>> Command with big BBOX does lead into segmantation fault. Unfortunately I
am just an amateur and I have no idea about what is a backtrace and how I
could provide it to you. The server is a virtual Linux box (Ubuntu).
>> -Jukka Rahkonen-
>> thomas bonfort wrote:
>>> the second one is incomplete, the request seems to be failing.
>>> can you run the request locally to see if it segfaults, and if so
>> provide a backtrace:
>>> /path/to/mapserver-cgi
QUERY_STRING='map=/path/to/map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDT
H=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BB
OX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&S
RS=EPSG:2393&STYLES='
>> thomas
>> On Wed, Aug 17, 2011 at 15:40, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
wrote:
>>> Hi,
>>>> This request from Mapserver 6.0 gives me a nice pdf file:
N=1.1.1&WIDTH=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE&FORMAT=applicat
ion/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827
.104097395&SRS=EPSG:2393&STYLES=
>>> However, if I double the bounding box the resulting pdf cannot be opened
by Acrobat reader.
N=1.1.1&WIDTH=1728&HEIGHT=1324&LAYERS=default&TRANSPARENT=TRUE&FORMAT=applic
ation/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,69578
27.104097395&SRS=EPSG:2393&STYLES=
>>> The latter gives fine image with format=image/png. Any idea about what
is going wrong?
>>> -Jukka Rahkonen-_______________________________________________
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1392 / Virus Database: 1520/3841 - Release Date: 08/17/11
