<Ext> Re: [mapserver-users] Problem displaying a NAD83 tile in
WGS84 (or via WMS)
Ed Resnick
eresnick at tapestrysolutions.com
Fri Aug 19 13:02:32 EDT 2011
Here's a WMS request, broken up for readability:
http://10.10.10.206/cgi-bin/mapserv.exe?map=E:/osm4326/mrsid.map
&service=WMS
&version=1.1.1
&request=GetMap
&layers=default
&format=image/png
&width=256
&height=256
&srs=EPSG:4326
&bbox=-122.875,45.25,-122.75,45.375
&transparent=TRUE
Here's the gdalinfo dump:
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
Files: wa.sid.sid
wa.sid.sdw
wa.sid.sid.aux.xml
Size is 1742, 1458
Coordinate System is:
PROJCS["NAD_1983_UTM_Zone_10N",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["false_easting",500000.0],
PARAMETER["false_northing",0.0],
PARAMETER["central_meridian",-123.0],
PARAMETER["scale_factor",0.9996],
PARAMETER["latitude_of_origin",0.0],
UNIT["Meter",1.0]]
Origin = (555230.000000000000000,5048039.000000000000000)
Pixel Size = (1.000009239300614,-1.000000000000000)
Metadata:
IMAGE__INPUT_NAME=C:\DOCUME~1\PAULW~2.ATT\LOCALS~1\Temp\img1AE.tmp
IMAGE__INPUT_FILE_SIZE=7619508.000000
GEO__spref_horizsys_cordsysn_geogcsn=GCS_North_American_1983
GEO__spref_horizsys_cordsysn_projcsn=NAD_1983_UTM_Zone_10N
GEO__spref_horizsys_planar_gridsys_gridsysn=Universal Transverse Mercator
GEO__spref_horizsys_planar_gridsys_utm_utmzone=10
GEO__spref_horizsys_planar_gridsys_utm_transmer_sfctrmer=0.999600
GEO__spref_horizsys_planar_gridsys_utm_transmer_longcm=-123.000000
GEO__spref_horizsys_planar_gridsys_utm_transmer_latprjo=0.000000
GEO__spref_horizsys_planar_gridsys_utm_transmer_feast=500000.000000
GEO__spref_horizsys_planar_gridsys_utm_transmer_fnorth=0.000000
GEO__spref_horizsys_planar_planci_plance=row and column
GEO__spref_horizsys_planar_planci_plandu=meters
GEO__spref_horizsys_planar_planci_coordrep_absres=1.000009
GEO__spref_horizsys_planar_planci_coordrep_ordres=1.000000
GEO__spref_horizsys_geodetic_horizdn=North American Datum of 1983
GEO__spref_horizsys_geodetic_ellips=Geodetic Reference System 80
GEO__spref_horizsys_geodetic_semiaxis=6378137.000000
GEO__spref_horizsys_geodetic_denflat=298.257222
IMAGE__COMPRESSION_VERSION=1,6,3
IMAGE__TARGET_COMPRESSION_RATIO=20.000000
IMAGE__COMPRESSION_NLEV=6
IMAGE__COMPRESSION_WEIGHT=4.000000
IMAGE__COMPRESSION_GAMMA=2.000000
IMAGE__COMPRESSION_BLOCK_SIZE=512
IMAGE__CREATION_DATE=Wed Dec 02 14:18:16 2009
IMAGE__NO_DITHER=0
VERSION=MG2
IMAGE__WIDTH=1742
IMAGE__HEIGHT=1458
IMAGE__NO_DATA_VALUE=15,172,40
IMAGE__TRANSPARENT_DATA_VALUE=0,0,176
IMAGE__COLOR_SCHEME=0
IMAGE__DATA_TYPE=0
IMAGE__XY_ORIGIN=555230.500005,5048038.500000
IMAGE__X_RESOLUTION=1.000009
IMAGE__Y_RESOLUTION=1.000000
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 555230.000, 5048039.000) (122d17'31.28"W, 45d35' 1.32"N)
Lower Left ( 555230.000, 5046581.000) (122d17'31.87"W, 45d34'14.07"N)
Upper Right ( 556972.016, 5048039.000) (122d16'10.90"W, 45d35' 0.81"N)
Lower Right ( 556972.016, 5046581.000) (122d16'11.51"W, 45d34'13.57"N)
Center ( 556101.008, 5047310.000) (122d16'51.39"W, 45d34'37.44"N)
Band 1 Block=1742x128 Type=Byte, ColorInterp=Red
Minimum=60.000, Maximum=222.000, Mean=119.606, StdDev=36.132
Overviews: 871x729, 436x365, 218x183, 109x92, 55x46, 28x23
Band 2 Block=1742x128 Type=Byte, ColorInterp=Green
Minimum=84.000, Maximum=220.000, Mean=133.956, StdDev=21.319
Band 3 Block=1742x128 Type=Byte, ColorInterp=Blue
Minimum=95.000, Maximum=205.000, Mean=119.015, StdDev=12.620
And finally here is the map file:
MAP
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "INTERLACE=false"
MIMETYPE "image/png"
END
NAME "MrSID"
IMAGETYPE agg
MAXSIZE 4000
SIZE 800 800
IMAGECOLOR "#B3C6D4"
WEB
METADATA
ows_enable_request "*"
labelcache_map_edge_buffer "-10"
wms_srs "EPSG:4326 EPSG:4269"
wms_title "MrSID"
wms_onlineresource "http://10.10.10.206/cgi-bin/mapserv.exe?map=E:/osm4326/mrsid.map"
END
END
CONFIG "PROJ_LIB" "C:\ms4w\proj\nad"
CONFIG "MS_ERRORFILE" "E:\errors.txt"
DEBUG 5
SHAPEPATH "E:/osm4326/MrSID/"
EXTENT -123.0 45.0 -122.0 46.0
UNITS dd
PROJECTION
"init=epsg:4326"
END
LAYER
METADATA
wms_title "A"
wms_group_title "default"
wms_srs "EPSG:4269"
wms_extent "555230 5046581 556972 5048039"
END
TYPE RASTER
STATUS ON
GROUP "default"
NAME "A"
PROJECTION
"init=epsg:4269"
END
EXTENT 555230 5046581 556972 5048039
DATA "wa.sid.sid"
END
END
________________________________________
From: Rahkonen Jukka [Jukka.Rahkonen at mmmtike.fi]
Sent: Thursday, August 18, 2011 9:51 PM
To: Ed Resnick; 'mapserver-users at lists.osgeo.org'
Subject: <Ext> Re: [mapserver-users] Problem displaying a NAD83 tile in WGS84 (or via WMS)
Could you give a bit more information? Your use case is the most common that exists and all instructions should be at http://mapserver.org/ogc/wms_server.html
It would be good to see the gdalinfo report of your image and your mapfile and the exact WMS request you were using including the WMS version. At least these parts of mapfile are important
MAP level: extent, projection and metadata (wms_srs and wms_inable_request at least)
LAYER level projection.
I can see some really odd LatLonBoundingBoxes in my own MS 6.0 WMS service too. I will investigate them a bit further. If it is just that the Mapserver is creating the GetCapabilities document wrong then the WMS service should still be usable.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Ed Resnick
> Lähetetty: 19. elokuuta 2011 2:47
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Problem displaying a NAD83 tile in
> WGS84 (or via WMS)
> I have a MrSID file in NAD83 projection (EPGS 4269) which I
> want to display via WMS in WGS84 projection (EPGS 4326). I
> cannot get this to work.
> I have tried setting the entire map-file's projection to
> 4269, with the extent specified in that projection (in
> meters), and shp2img shows the image, but attempting to view
> it via WMS (requesting the 4326 projection) does not work,
> and the GetCapabilities response file is completely wrong -
> the LatLonBoundingBox tags actually list the 4269 bounding
> box in meters. Excerpt:
> <LatLonBoundingBox minx="555230" miny="5.04658e+006"
> maxx="556972" maxy="5.04804e+006" />
> <BoundingBox SRS="EPSG:4269"
> The BoundingBox is correct; the LatLonBoundingBox obviously is not.
> I have also tried specifying 4326 as the map projection and
> 4269 as the layer projection, with the map's extent in
> lat/lon and the layer's extent as the above value (meters).
> Not only did this not work, but even shp2img just shows a
> blank image. If I change the map's extent to the value in
> meters (even though its projection is specified as 4326),
> then shp2img works, but the WMS feed still does not; the
> GetCapabilities still is wrong.
> Is MapServer simply buggy or is there a
> solution?_______________________________________________
