[mapserver-users] RE: Error with WFS request from MapInfo
Jelmer Baas
baas at speerit.nl
Fri Aug 19 05:44:46 EDT 2011
Jukka,
Thanks for your pointers, I'll check out other WFS servers and see how far I get. I did add the extent as EXTENT -180 -90 180 90 in the map file but that doesn't seem to change anything.
Regards
Jelmer Baas
> -----Original Message-----
> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
> Sent: vrijdag 19 augustus 2011 11:05
> To: Jelmer Baas; 'mapserver-users at lists.osgeo.org'
> Subject: Re: Error with WFS request from MapInfo
> Hi,
> I would start by addind EXTENT to MAP level. WFS 1.0.0 does not support
> reprojection so select the desired output srsName and use that as map level
> PROJECTION. Express extents to suit that projection.
> Mapserver has been pretty poor WFS server for real GIS clients but it is
> getting better. However, I cannot promise you any amazing interoperability.
> At least I would recommend you to update to 6.0. If you want to get some
> good feelings about WFS consider having a try with TinyOWS first. It works
> only with PostGIS (v. 1.5 or higher) but that looks to be OK for you. I have
> managed to read features from TinyOWS with Kosmo GIS, gvSIG, QGis, uDig,
> ArcGIS, MapInfo, Gaia, SIS Map Browser and iGeoDesktop. With some clients
> even attribute and spatial filters work. Come back to Mapserver WFS later
> and start making bug reports. Glad that you learned already to study the
> POST traffic, it is really a must with WFS debugging. I am using Fiddler for that
> purpose.
> MapInfo seems to send a most basic WFS call (or stupid, just orders the
> whole layer from you) so that should not be a trouble in this case. Once you
> get the extents corrected you can continue and wait excited if MapInfo will
> have troubles with checking the schemas and parsing the GML that comes
> from Mapserver.
> -Jukka Rahkonen-
> > -----Alkuperäinen viesti-----
> > Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Jelmer Baas
> > Lähetetty: 19. elokuuta 2011 11:26
> > Vastaanottaja: mapserver-users at lists.osgeo.org
> > Aihe: [mapserver-users] Error with WFS request from MapInfo
> > Hello list,
> > I've been struggling with this issue for a while, now. When I
> > try to add a WFS layer in MapInfo, I receive the following
> > error (from the mapserver logfile):
> > prepare_database(): Query error. Error declaring cursor:
> > ERROR: BOX3D parser - couldnt parse. It should look like:
> > BOX3D(xmin ymin zmin,xmax ymax zmax) or BOX3D(xmin ymin,xmax
> ymax)
> > LINE 1: ...:text from pandactueel WHERE geometrie &&
> > setSRID('BOX3D(-1....
> > With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
> > asbinary(force_collection(force_2d(geo)),'NDR'),oid::text
> > from mytable WHERE geo && setSRID('BOX3D(-1.#INF
> > -1.#INF,1390604146415.56 -16080812.3872859)'::BOX3D, 28992 )
> > The layer itself works, via normal GetMap requests.
> > This is my mapfile:
> > MAP
> > NAME TEST
> > STATUS ON
> > UNITS meters
> > FONTSET "fontset.txt"
> > DEBUG 5
> > CONFIG "MS_ERRORFILE" "c:\temp\mapserver.log"
> > IMAGECOLOR 255 55 255
> > OUTPUTFORMAT
> > NAME aggpng24
> > DRIVER AGG/PNG
> > TRANSPARENT ON
> > IMAGEMODE RGBA
> > MIMETYPE "image/png"
> > EXTENSION "png"
> > END
> > WEB
> > METADATA
> > "wms_title" "TEST"
> > "wfs_title" "TEST"
> > "wms_srs" "epsg:4326 epsg:900913"
> > "wfs_srs" "epsg:4326 epsg:900913"
> > "wms_onlineresource" "***"
> > "wfs_onlineresource" "***"
> > END # METADATA
> > END #web
> > SYMBOLSET "symbols_mapinfo2.sym"
> > PROJECTION
> > "init=epsg:4326"
> > END
> > LAYER
> > TYPE POLYGON
> > STATUS ON
> > DUMP TRUE
> > CONNECTIONTYPE POSTGIS
> > CONNECTION "host=localhost dbname=TEST user=postgres
> > password=*** port=5432"
> > DATA "geo from mytable using unique oid using srid=28992"
> > NAME mytest
> > CLASS
> > NAME " mytest "
> > STYLE
> > COLOR 0 0 250
> > OUTLINECOLOR 0 250 0
> > END
> > END
> > PROJECTION
> > "init=epsg:28992"
> > END
> > MINSCALE 1
> > MAXSCALE 80000000
> > METADATA
> > "wms_title" " mytest "
> > "wfs_title" " mytest "
> > "gml_featureid" "oid"
> > "gml_include_items" "all"
> > END # METADATA
> > END
> > END # Map File
> > MapInfo sends its requests as post (I'd prefer get...) and
> > after using a packet sniffer I found out it sends this:
> > <?xml version="1.0" encoding="utf-8"?>
> > <GetFeature version="1.0.0" service="WFS" outputFormat="GML2"
> > xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> > xmlns:gml="http://www.opengis.net/gml"
> > xmlns:ogc="http://www.opengis.net/ogc"
> > xmlns="http://www.opengis.net/wfs"
> > xsi:schemaLocation="http://www.opengis.net/wfs
> > ../wfs/1.0.0/WFS-basic.xsd"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><Query
> > typeName=" mytest"/></GetFeature>
> > I use MapServer version 5.4.2, by the way.
> > Can anyone tell me what I'm missing? Should I add extends in
> > the MapFile or something? And where do those weird numbers come
> from?
> > Regards,
> > Jelmer Baas
> > Speer IT B.V.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
