[mapserver-users] Re: Raster Data from PostGIS
florencia.bujan florita026 at gmail.com
Mon Aug 22 09:23:06 EDT 2011
Buenos días Gustavo,
Al final no pude encontrar como hacer esto, la única herramienta que estuve
probando fue el GDAL (te genera una capa de rasters variables). Terminé
almacenando los rasters en un directorio (en lugar de la Geodatabase) y
levantandolos desde ahí.
Disculpame que no te pude contestar antes.
Saludos y a las órdenes por cualquier otra consulta,
Florencia de Uruguay.
2011/8/19 Gustavo1376 [via OSGeo.org] <
ml-node+6701922-1641837362-295788 at n2.nabble.com>
> Hi Florencia, i am Gustavo from Uruguay.
> Have you finally found the way to load a raster from a PostGis database?
> I'm trying to do that but no had no success yet.
> In my case the problem is that my application would generate a new raster
> everyday, so if i save them to disk it quickly will get out of space. So my
> option is to store the rasters in the database, with it's dedicated storage
> and (i hope) special methods for optimizing it's storage capacity. I mean, i
> think that a PostGis with 500GB storage capacity should be able to store
> much more images than a flat file system with same capacity.
> Well, i'll be pleased if you could share your solution (if finally found
> any).
> Regards,
> Gustavo.
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/Raster-Data-from-PostGIS-tp5784362p6701922.html
>  To unsubscribe from Raster Data from PostGIS, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5784362&code=Zmxvcml0YTAyNkBnbWFpbC5jb218NTc4NDM2MnwtMTA5MjA5NTEwMA==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Raster-Data-from-PostGIS-tp5784362p6711536.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110822/5db17b60/attachment.html
