[mapserver-users] Extra "?" in WCS query
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 23 07:36:58 EDT 2011
The wrappers that Frank and Jukka refer to are documented for unix and
windows/apache and windows/iis at:
http://www.mapserver.org/ogc/wms_server.html#more-about-the-online-resource-url
I use that section myself to remove the map parameter all the time :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-08-23 6:55 AM, Rahkonen Jukka wrote:
> Frank Warmerdam wrote:
>> If so, the problem is with ArcMap, and you should file a
>> ticket with them.
>> In the meantime, you can wrap the WCS service so that the map does not
>> need to be defined in the URL. On Linux I would normally accomplish
>> this by putting a shell script in the cgi-bin directory that
>> defines the
>> MS_MAPFILE environment variable. I'm not so sure how to
>> accomplish this
>> on Windows, though you could likely add MS_MAPFILE's
>> definition in your
>> Apache configuration if it is unlikely to cause conflicts on any other
>> service run from the same apache.
> Hi
> I do not know if this is elegant but it works on Windows
> 1. Copy the mapserv.exe file in the cgi-bin directory and name a copy to whatever you want to use in the ServiceURL, for example testi_wcs1
> 2. Edit Apache httpd.conf file and add a new line
> SetEnvIf Request_URI "/cgi-bin/testi_wcs1" MS_MAPFILE=d:/ms4w/maps/testi_wcs1.map
> 3. Restart Apache
> Now if the service url is pointing to /cgi-bin/testi_wcs1? MS_MAPFILE is set to d:/ms4w/maps/testi_wcs1.map automatically. Make more copies of mapserv.exe and add new lines into httpd.conf when you will have a need short urls for testi_wcs2 and others.
