[mapserver-users] How to define this projection?
Stephen Woodbridge woodbri at swoodbridge.com
Wed Aug 24 22:20:33 EDT 2011
On 8/24/2011 9:48 PM, jjwang wrote:
> This the summary of my shapefile.
> Layer name: tas101sb
> Geometry: Polygon
> Feature Count: 971
> Extent: (143.833316, -43.742980) - (148.498760, -39.437430)
> Layer SRS WKT:
> GEOGCS["GCS_WGS_1984",
>      DATUM["WGS_1984",
>          SPHEROID["WGS_1984",6378137.0,298.257223563]],
>      PRIMEM["Greenwich",0.0],
>      *UNIT["Degree",0.0174532925199433]]*
> AREA: Real (20.5)
> PERIMETER: Real (20.5)
> TAS101SB_: Real (11.0)
> TAS101SB_I: Real (11.0)
> SUBURB: String (46.0)
> SOURCE: String (16.0)
> UFI: Integer (10.0)
> I'm assuming that 'Layers SRS WKT' defines the projection of the layer.
> Is this projection same as EPSG:4326?
Yes that is correct. epsg:4326
> If not, can some one give me the Proj4 statement that defines this
> projection.
> JJ
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-define-this-projection-tp6722964p6722964.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
