[mapserver-users] msQueryByFilter(): Search returned no results.
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 26 00:30:38 EDT 2011
Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
-Jukka Rahkonen.
Michal Šrédl wrote:
> Hi all,
> problem solved. I needed to set:
> EXTENT -905000 -1230000 -400000 -900000
and
PROJECTION
## "init=epsg:4326"
"init=epsg:102067"
END
(Epsg 102067 is the projection of the layer being filtered.)
Thank you very much again,
Michal
2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
> Hi Steve,
> Thanks a lot. The extent should be large enough to encompass all the
> features. Here comes the whole mapfile:
> MAP
> NAME "MIS WFS Server"
> STATUS ON
> SIZE 500 500
> EXTENT -180 -90 180 90
> SHAPEPATH "data/"
> IMAGECOLOR 255 255 255
> CONFIG MS_ERRORFILE "log/mapserv.log"
> DEBUG 5
> WEB
> IMAGEPATH "/var/www/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wfs_title" "MIS WFS Server" ## REQUIRED
> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
> "wfs_srs" "EPSG:4326 EPSG:102067"
> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
> "ows_enable_request" "*"
> "ows_updatesequence" "2011-29-05T00:24:00"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME "typ"
> METADATA
> "wfs_title" "Typologie" ## REQUIRED
> "wfs_include_items" "all"
> "gml_featureid" "CISLO" ## REQUIRED
> "gml_include_items" "all" ## Optional (serves all attributes for layer)
> "gml_types" "auto"
> "gml_geometries" "msGeometry"
> "gml_msGeometry_type" "polygon"
> END
> DATA typ.shp
> TYPE POLYGON
> STATUS ON
> PROJECTION
> "init=epsg:102067"
> END
> DUMP TRUE ## REQUIRED
> CLASS
> NAME "Typ"
> STYLE
> COLOR 0 0 155
> OUTLINECOLOR 120 120 120
> END
> TEMPLATE "templates/typ_zver.html"
> END
> DEBUG 5
> END # Layer
> LAYER
> NAME "hsrs"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
> DEBUG ON
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
> "wms_title" "CR Topo"
> "wms_server_version" "1.1.1"
> "wms_format" "image/png"
> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
> END
> END
> END # Map File
> Cheers,
> Michal
> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>> Sent from my iPad
>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>> Hi all,
>>> I am trying to use FES filter for WFS layer and get no result, even
>>> thought I should get one.
>>> In my browser, I request
>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>> and get
>>> <wfs:FeatureCollection
>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>> xmlns:gml="http://www.opengis.net/gml"
>>> xmlns:wfs="http://www.opengis.net/wfs"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>> <gml:boundedBy>
>>> <gml:Null>missing</gml:Null>
>>> </gml:boundedBy>
>>> </wfs:FeatureCollection>
>>> even though I do know, that features with ZVER=2 do exist.
>>> In the mapserver log file, I get
>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>> no results. No matching record(s) found.
>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>> (msLoadMap not incl.): 0.002s
>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>> "msQueryByPoint: search returned no results" and tried to create a
>>> simple template:
>>> <!-- MapServer Template -->
>>> <tr>
>>> <td>[lrn]</td>
>>> <td>[ZVER]</td>
>>> </tr>
>>> but with no effect.
>>> In the mapfile, there is
>>> LAYER
>>> NAME "typ"
>>> METADATA
>>> "gml_types" "auto"
>>> END
>>> DATA typ.shp
>>> TYPE POLYGON
>>> STATUS ON
>>> PROJECTION
>>> "init=epsg:102067"
>>> END
>>> CLASS
>>> NAME "Typ"
>>> STYLE
>>> COLOR 0 0 155
>>> END
>>> END
>>> DEBUG 5
>>> END # Layer
>>> What is wrong with my FES filter? How can I make it to run?
>>> Thanks a lot,
>>> Michal
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
