[mapserver-users] msQueryByFilter(): Search returned no results.
Michal Šrédl
michal.sredl at gmail.com
Fri Aug 26 06:57:36 EDT 2011
Hi Jukka,
the current settings returns expected result with &srsName=EPSG:4326
as well. The original settings doesn't work neither with
&srsName=EPSG:4326 nor &srsName=EPSG::102067.
Yes, it looks like there would be a problem in case of several WFS
layers with different projections of the source data.
Cheers,
Mike
2011/8/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> Hi,
> Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
> Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
> -Jukka Rahkonen.
> Michal Šrédl wrote:
>> Hi all,
>> problem solved. I needed to set:
>> EXTENT -905000 -1230000 -400000 -900000
> and
> PROJECTION
> ## "init=epsg:4326"
> "init=epsg:102067"
> END
> (Epsg 102067 is the projection of the layer being filtered.)
> Thank you very much again,
> Michal
> 2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
>> Hi Steve,
>> Thanks a lot. The extent should be large enough to encompass all the
>> features. Here comes the whole mapfile:
>> MAP
>> NAME "MIS WFS Server"
>> STATUS ON
>> SIZE 500 500
>> EXTENT -180 -90 180 90
>> SHAPEPATH "data/"
>> IMAGECOLOR 255 255 255
>> CONFIG MS_ERRORFILE "log/mapserv.log"
>> DEBUG 5
>> WEB
>> IMAGEPATH "/var/www/tmp/"
>> IMAGEURL "/tmp/"
>> METADATA
>> "wfs_title" "MIS WFS Server" ## REQUIRED
>> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
>> "wfs_srs" "EPSG:4326 EPSG:102067"
>> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
>> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
>> "ows_enable_request" "*"
>> "ows_updatesequence" "2011-29-05T00:24:00"
>> END
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> LAYER
>> NAME "typ"
>> METADATA
>> "wfs_title" "Typologie" ## REQUIRED
>> "wfs_include_items" "all"
>> "gml_featureid" "CISLO" ## REQUIRED
>> "gml_include_items" "all" ## Optional (serves all attributes for layer)
>> "gml_types" "auto"
>> "gml_geometries" "msGeometry"
>> "gml_msGeometry_type" "polygon"
>> END
>> DATA typ.shp
>> TYPE POLYGON
>> STATUS ON
>> PROJECTION
>> "init=epsg:102067"
>> END
>> DUMP TRUE ## REQUIRED
>> CLASS
>> NAME "Typ"
>> STYLE
>> COLOR 0 0 155
>> OUTLINECOLOR 120 120 120
>> END
>> TEMPLATE "templates/typ_zver.html"
>> END
>> DEBUG 5
>> END # Layer
>> LAYER
>> NAME "hsrs"
>> TYPE RASTER
>> STATUS ON
>> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
>> DEBUG ON
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_srs" "EPSG:4326"
>> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
>> "wms_title" "CR Topo"
>> "wms_server_version" "1.1.1"
>> "wms_format" "image/png"
>> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
>> END
>> END
>> END # Map File
>> Cheers,
>> Michal
>> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>>> Sent from my iPad
>>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>>> Hi all,
>>>> I am trying to use FES filter for WFS layer and get no result, even
>>>> thought I should get one.
>>>> In my browser, I request
>>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>>> and get
>>>> <wfs:FeatureCollection
>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>> xmlns:gml="http://www.opengis.net/gml"
>>>> xmlns:wfs="http://www.opengis.net/wfs"
>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>>> <gml:boundedBy>
>>>> <gml:Null>missing</gml:Null>
>>>> </gml:boundedBy>
>>>> </wfs:FeatureCollection>
>>>> even though I do know, that features with ZVER=2 do exist.
>>>> In the mapserver log file, I get
>>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>>> no results. No matching record(s) found.
>>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>>> (msLoadMap not incl.): 0.002s
>>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>>> "msQueryByPoint: search returned no results" and tried to create a
>>>> simple template:
>>>> <!-- MapServer Template -->
>>>> <tr>
>>>> <td>[lrn]</td>
>>>> <td>[ZVER]</td>
>>>> </tr>
>>>> but with no effect.
>>>> In the mapfile, there is
>>>> LAYER
>>>> NAME "typ"
>>>> METADATA
>>>> "gml_types" "auto"
>>>> END
>>>> DATA typ.shp
>>>> TYPE POLYGON
>>>> STATUS ON
>>>> PROJECTION
>>>> "init=epsg:102067"
>>>> END
>>>> CLASS
>>>> NAME "Typ"
>>>> STYLE
>>>> COLOR 0 0 155
>>>> END
>>>> END
>>>> DEBUG 5
>>>> END # Layer
>>>> What is wrong with my FES filter? How can I make it to run?
>>>> Thanks a lot,
>>>> Michal
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
