[mapserver-users] Re: Dashed outline for polygon (migration to 6.0)
Petra Pietrasová petra.pietrasova at sitewell.cz
Mon Aug 29 08:59:31 EDT 2011
Thank you ,
but even your example doesn´t work.
Are you using the version of mapserver 6.0.1 and does dashed line work in
it? if it works to you than the problem is not in the layer in the style of
layer.
Do you have any idea what we do wrong? Some setup of mapserver or output?
We are using AGG output as I wrote before...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Dashed-outline-for-polygon-migration-to-6-0-tp6728657p6737544.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
