[mapserver-users] Problem GetFeature with geom filter on WFS
Stéphane Brunner
stephane.brunner at camptocamp.com
Mon Aug 29 09:12:38 EDT 2011
Hello,
2011/8/24 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> Hi,
> I am not too familiar with PostGIS, but isn't this && exactly an index based
> BBOX query which is checking if the BBOX of the feature is intersecting with
> the BBOX of the reference geometry?
> where geom &&
>> >> GeomFromText('POLYGON((620000 218000,620000 278000,690000
>> >> 278000,690000 218000,620000 218000))',-1)
This BBox is the Extents of the mapfile than in our case it always return true.
> Then perhaps what you wrote
> "MapServer filters them correctly but as we get
>> only the 100 first results from the DB, we miss many objects and/or
>> they are not related to the area where we want to apply a geographical
>> filter. "
> could better be written "as we get only the 100 first results within the
> BBOX filtered with fast but inaccurate index search, the result set after
> Mapserver applying a geographical filter may have less that 100 features".
Yes, but with a so large BBOX (extent from the mapfile, not geometry
extent) in most cases it returns 0 results.
Sincerely
Stéphane Brunner
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
camptocamp.com
mapfish.org
